Puzzled on this part
Ya’akov
Joined Jan 27, 2019
10,370
It used for a sound activated device I’m trying to repair.
If the device doesn't make sounds, then it could be using the component as a microphone which is just the reverse of using it to make sounds.
Why do you think it is defective? How have you tested it?
DickCappels
Joined Aug 21, 2008
10,661
If it is a piezoelectric transducer as mrchips indicated (and I share his opinion) your application might not work well or at all unless you replace the transducer with one that resonates at the same frequency. It depends on the application and the way the transducer is driven. To summarize, success is most likely to be achieved if you can find an identical replacement part.
Rayhawk456
Joined Oct 24, 2019
8
That’s my problem, finding an identical part. There is no markings on it and it no longer functions. The picture was for id only. I’m trying to repair a sound activated decoration of my wife’s. Thanks for your response.
DickCappels
Joined Aug 21, 2008
10,661
Then it looks like the only thing you can do is get some and try them. Have you ever seen it used -if so, could you hear any sounds being emitted by it when activated?
35,320
Tell us more clearly what the device does.
When the device detects sound, what is supposed to happen after that? Is there any sound output?
It seems unusual for such a device to use a piezoelectric transducer as a sound detector.
Is there a microphone anywhere on the device?
Rayhawk456
Joined Oct 24, 2019
8
No microphone other than this disc. When it detects sound it starts moving.
Ya’akov
Joined Jan 27, 2019
10,370
Impulse noise would be a use case for a piezo microphone. You might find that any raw piezo works, but many piezo buzzer contain active electronics which would not.
How do you know the fault is in the transducer?
Rayhawk456
Joined Oct 24, 2019
8
It functions properly except sound will not activate it
