HP it still just drives me crazy that high PE light is called _cold_ and low PE light is called _warm_Prehaps the 'icy' glare of Hg vapor lamps would cool you off?
TTFN
HP![]()
TTFN
HP![]()
I don't wonderHP I'm sry for more delays cuz MMK cap just melted
Agreed...which I say wasn't to do with different setup just polyester dielectric isn't suited for resonance cap so it just happened to fail when it did
'Tuning' of the circuit is sufficiently arduous sans 'factoring' of dielectric material into the 'permutations' - please be advised that single-unit MKP 10 capacitors are wholly satisfactory in your application whereas FKP 1 is 'over kill'Anyhow I'm back to square one with original circuit trying to find right capacitance using MKP and FKP
finding resonant like you say _sweet spot_ is so hard cuz just close is same performance as way off so there's nothing to go by
1) Measure the parallel equivalent inductance of the entire primary winding (all other windings 'open').HP If you have any suggestions I could use the help!
Pleased to hear it!I have tomorrow through weekend free so I'll keep at it![]()
Where is that coming from? -- Seriously! The thought never crossed my mind! -- When you don't want to do something you refuse outright!HP don't you dare try to say I'm just stalling cuz if I was disingenuous puke I could have just made up plausible figures to post!
Agreed and ditto!So plz just be patient
I hear ya! -- FWIW I've long regarded embodiment of 'nonentities' (e.g. 'cold' and 'dark') to be second only to 'quantification of units' (can we say 'voltage'?HP it still just drives me crazy that high PE light is called _cold_ and low PE light is called _warm_! HP I know you were saying ppl probably call red end of spectrum _warm_ cuz it's reminiscent of firelight and associated with other IR heat sources and all that but it's still totally lame! So they just need to think on totally basic middle school thermodynamics to have concept of bb radiation and color temperature
Aye! That'd explain your loss of patience -- Recall my warning? To wit:HP I've spent days trying different caps for resonance
Thus it seems too much work and no play makes Aleph aBe advised that manic bouts of auto-depilation, apodysophilia, head 'thumping' and/or attempted self-immolation are merely nature's way of telling you it's time for a break
To be fair, it has long been my observation that the 'core' 4HV membership are highly competent -- But yes! The so called 'ZVS' (a.k.a. Mazilli Royer oscillator) is both widely misunderstood and prey of 'co-option' by abject ignoramuses the web overIt reminds me of those _ZVS_ drivers that 4HV fanboys orgasm over cuz they're too ignorant to understand that it's strike distance not drawn distance that is measure of voltage!
No you're not!HP I'm sry if you disagree
The trouble with 'flyback' (i.e. 'energy storage') topoligies in this application are several -- Principally (in descending order of significance):HP I say IMPWM is only way to go but you don't like pulse topologies so
It is my experience that Spice (in general) is best regarded as a powerful educational tool only! -- That said - I find it rather curious that LtSpice (being, as it is, a product of Linear Technologies - largely a manufacturer of power supply components) is far less suited to 'power electronics' than are certain 'general' electronics CAD suitesHP here's another thing! Ltspice needs euthanasia! I'm going back to Orcad cuz at least it tells the truth %50 of the time
Actually, Spice packages aren't particularly expensive (a few hundred dollars being typical for a single EUL) -- FWIW I feel LtSpice's popularity owes to it's ubiquity - my $.02...I say the only reason for popularity of ltspice is its _price tag_ and that attitude is more than lame its tragic and scary!
When you've done stamping your feet and holding your breath -- please try this:I'm done!
HP Sry but NO! Cuz you don't get it! I'm all done with self oscillating circuits cuz they don't work for me! HP you have like charmed touch with Royer and Royer-like HV inverters! Cuz when you power your designs up it's all corona, arcs, sparks, ozone and just every sort of HV commotion! All I can get with pwr oscillator design is weak 20kv or hot 10kv arcs and IT DOESN'T HELP NO MATTER HOW MUCH I EFF AROUND WITH IT!When you've done stamping your feet and holding your breath -- please try this:
Construct the 'plain vanilla' Royer circuit (sans the transformer and resonant capacitor) in a project box. Use 2N3773 BJTs mounted to a heatsink via TO-3 'sockets' (for further convenience you may wish to consider using 'thermal-mat' style insulators/heat-transfer media).
Bring out the base and collector connections via color coded leads to alligator clips/test hooks.
Solder small alligator clips/test hooks to several 330nF MKP10 caps (400VAC/1kVDC)
With the above described arrangement you will be able to rapidly evaluate many combinations of resonant capacitance, winding ratios, etc... sans undue 'agro'![]()
@Aleph(0) You surprise me! -- Temperament doesn't become you! Perhaps you should step back for a few days then re-approach it with a fresh perspective? -- I assure you that power oscillator topologies represent practical, tried and true design - no mysticism required!HP Sry but NO! Cuz you don't get it! I'm all done with self oscillating circuits cuz they don't work for me!
HP I know it but it just drives me crazy when everything I try to improve it from non resonant setup just lowers output voltage and raises output currentYou surprise me! -- Temperament doesn't become you! Perhaps you should step back for a few days then re-approach it with a fresh perspective? -- I assure you that power oscillator topologies represent practical, tried and true design
HP tnx plz just send whatever you think I needI can send the 'retro-breadboarding' supplies as soon as you let me know...![]()
That's where test 'rigs and jigs' are invaluable for their reduction/mitigation of 'research fatigue'I know it but it just drives me crazy when everything I try to improve it from non resonant setup just lowers output voltage and raises output current![]()
Then I suggest you don't argue with them! -- Merely advise them of the facts, provide them with one or more references and move on!I'm also tired of arguing with total idiots who don't understand that voltage determines strike distance!
But there's no need for 'modern gear' in that pursuit! -- Merely use a Tektronix 'boat anchor' (e.g. A 545B equipped with a 'CA' PIU) with appropriate probes, etc - and all should be peachy!I can't analyze circuit properly cuz like you say HV and modern test gear don't mix![]()
Will do -- it may be as late as tomorrow evening/early Thursday AM though...Also plz post images cuz I can't get it in my mind? I say to post on forum cuz it's something other interested ppl will want to see too!
Here ya go!HP tnx plz just send whatever you think I need! Also plz post images cuz I can't get it in my mind? I say to post on forum cuz it's something other interested ppl will want to see too
Plz show closeups of what you're calling _blocks_
Will do -- Give me a couple of days...plz upload pics to blog with detailed description so everyone can benefit!
Soft and aromatic woods are quite flammable, exhibit greater electrical conductivity, and tend to warp with age...HP why is some wood better to use than others?
To reduce surface conductivity and seal out moisture/contaminants - additionally, certain hardwoods (especially hickory) are degraded by atmospheric O2 (to say nothing of the levels of O3 exposure inherent to the intended application!)You say to seal board with wax but why?
Via - would you believe... wood screwsAlso how do connection _blocks_ fasten to board?
Agreed!I say HV breadboard should be recommend as required materials
Absolutely! Hence my 'strategy' of regarding the board as a 'soft' ground...Wood can be partly conductive and at high voltage that can be a big problem.
Although I don't 'count' on the board's electrical characteristics - I take measures to reduce conductivity as much as possible (via, for example; wood species selection for high density/low moisture, 'waxing' and avoidance of treated/laminated lumber) -- Still, I feel it's best viewed as a 'weak ground'Of course it also depends how you are using it.
HP So I picked up parcel with breadboard kit! TNX! Cuz I can tell it's high quality components
I'll get to it (i.e. uping terminal-strip detail images) when I'm good and ready! -- And NO! I'm not going to design/build your circuit for you! (Nice try!)But I say a few more pics showing wired example circuit will be helpful so plz just breadboard simple circuit on your setup and post pics![]()
Essentially correct...So now I'm thinking that's rationale for mazilli circuit which I say is just cc circuit modified so drain voltage can be higher than gate voltage.
HP now I've got to say I'm just not impressed with mazilli circuit at all! Like I said b4 it's strong on current and totally lame on voltage!
Generally speaking; Well conceived Mazzilli topology/design applied to EHT 'production' will feature greater primary impedance than strictly necessarily with 'straight' resonant Royer implementations (all else being equal)...HP plz just tell me how to overcome that cuz yours is 50kv ac right off the secondary with white arcs! Best I can do is abt 10kv no matter what!
That and sinusoidal output...HP here's another question plz just tell me if I'm correct to say that desirability of resonant design is cuz of _softer_ switching?
Would you believe... the leakage inductance and 'tank' capacitance!?!?Also what determines frequency of oscillator when secondary is totally shorted?
