Push pull amplifier biasing
demir-ali
Joined Jul 13, 2024
324
Hi , I was practicing the pushpull amplifier , then I figured out that circuit performs better without diode biasing. I share my simulation with you. If it is not , at least I think it should be not better , can you explain me please ?
35,280
How do you define "performs better"?
Diodes are often used clamped to the heatsink on which the output transistors are mounted.
Because of the negative temperature coefficient, the diodes prevent thermal run-away.
demir-ali
Joined Jul 13, 2024
324
I said depending on output voltages but yes it is not. I just wondered.
dl324
Joined Mar 30, 2015
18,491
The diodes bias the transistors so they're always on to minimize crossover distortion. It works best when the diode drops match the base-emitter junction drops. Your simulations don't show any crossover distortion.
Where have you seen circuits drawn as you've shown? They were obviously drawn by someone who doesn't know what they're doing.
35,280
The diodes are not there to avoid cross-over distortion. You can avoid cross-over distortion using bias resistors.
Cross-over distortion is avoided by biasing the transistors in the linear region.
When the bases are connected, the transistors are class-B amplifiers. There is severe cross-over distortion.
You want to move away from class-B and move towards class-A, hence it is called class-AB.
You want to increase the bias voltage, i.e. separate the two base voltages. You can do this with bias resistors or with diodes.
Using two or more diodes (also with additional resistors) is a convenient way of providing two P-N junction forward voltages which gets you closer to a class-AB amplifier.
Audioguru again
Joined Oct 21, 2019
6,826
In the original circuit, without the diodes then both transistors in series are operating in class-A and drawing a very high current all the time.
Each 1k base bias resistor has (5V/2)- 0.7V= 1.8V across it resulting in a base current of 1.8mA. The typical hFE of 300 for the BC547C results in a collector current of 1.8mA x 300= 540mA even without a signal. But the BC547C transistor has a MAXIMUM ALLOWED CURRENT OF ONLY 500MA.
The heating in each transistor is (5V/2) x 540mA= 1.35W all the time. But the BC547C transistor has a MAXIMUM ALLOWED HEATING of only 0.625W.
With the diodes, the average transistor current without a signal is only about 20mA and the heating in each transistor is only about 0.05W.
28,515
With audio amplifiers, including complementary ones, there is always a compromise between efficiency and distortion. Crossover distortion is a challenge indeed. I suggest studying the output sections of good quality audio amplifiers to see how a solution is reached, and then using a simulator to evaluate the effects of changes to the component values. It is often possible to learn a lot from observing how others have succeeded.
35,280
Study the biasing in this circuit.
You can replace Q1 and Q3 with NPN transistor 2N3904 and Q2 with PNP transistor 2N3906.
R6 provides negative feedback.
demir-ali
Joined Jul 13, 2024
324
I worked on this , Q3 is preamplifying the signal , and remaining part is same. R3 and R4 changes gain. I guess R1 and R2 is for cables inner resistances.
But with Q3 , circuit gets distorted earlier compared to other setup. I upload both setups with asc file. Can you detail it to me please ?
ericgibbs
Joined Jan 29, 2010
21,629
Hi demir,
You are over driving the Amp input, also made minor changes in the values.
The amp needs further design changes.
You must take more care when drawing and laying out your simulations, also use Labels at the Nodes. F4.
E
demir-ali
Joined Jul 13, 2024
324
Hi demir,
E
Hi Eric , seems like R5 must be small for higher current ability of amplifier. Is that right ?
I will try to make my circuits more readable.
Also it is good to see you again :D
