pulsing the resistive load on 310 v dc
ulzi
Joined Dec 16, 2018
11
i need to pulse resistive load on 310 v DC, ( rectified 220 v AC) , power on load will be is around 300-400 watt.
should i need bulky and expensive isolation transformer ?
and also how i take 15-20 v dc (for supply pulse generator to switch transistor ) from this rectified 310 v DC ?
MaxHeadRoom
Joined Jul 18, 2013
30,686
What do you have exactly and what are you trying to do?
A simple Triac controller, either burst firing or phase angle control could be used on the AC, but more info needed!
Fairchild AN-3006, AN-3003
Max.
ulzi
Joined Dec 16, 2018
11
Max.
i meant , similar this ,
excluding isolation transformer, how is this on safety ?
and that 12 v dc for transistor switch , how i can get from same source , here from AC 220 v ?
ericgibbs
Joined Jan 29, 2010
21,460
hi ulzi,
Moderation:
You must use an isolation transformer, or the Thread will be Closed.
Non isolated mains power supplies contravenes AAC's T&C's
E
