Justin Spencer
- Joined Jul 22, 2017
- 15
Hello,Hello ALL,, what is the official name for a pulsed input > constant output circuit, anyone know if there's a prebuilt cheap china kit I can buy or is it easy to knock one together with a few components
Ive got a pulsed input thats flashing a alarm (when triggered) light, I want the pulsed signal to be a constant signal to switch on a relay, this is all on a 12v system, is this poss?
Thank you for the question, I hope I can answer it well.
A pulsed signal can be toned down to DC level with a low pass filter (LPF)
I think a simple LC circuit will do (assuming a bessel-shaped frequency response is okay)
This is highly similar to how switching converters operate, albeit for this case
there is no feedback or control circuit to regulate the frequency.
However, I think you're planning to feed this DC voltage to a relay which draws significant current.
In doing so, you might need to use a buffer in between the relay and LC circuit
to provide ample loading current to the relay.
I hope I was able to help in some way and will try to answer any further questions or inquiries.
Thank you very much for spending time reading my reply.
Best regards,
Justin
