try this bit of code to see if it will work with what you need, this should allow you to access the database using ADO...
Just paste it into the forms code window and add a command button to the form... and make the appropriate changes to the code to reflect your info to pass to the database..
Also, check this out for other info on MySQL connection strings >>http://www.connectionstrings.com/mysql
B. Morse
Rich (BB code):
Dim strDataBaseName As String
Dim strDBCursorType As String
Dim strDBLockType As String
Dim strDBOptions As String
Dim rs As ADODB.Recordset
Dim cn As ADODB.Connection
Private Sub Command1_Click()
On Error GoTo Command1_Click_Error
Dim b as Long
strDBCursorType = adOpenDynamic 'CursorType
strDBLockType = adLockOptimistic 'LockType
strDBOptions = adCmdText 'Options
Set cn = New ADODB.Connection
Me.MousePointer = 11
cn.Open ConnectString()
With cn
.CommandTimeout = 0
.CursorLocation = adUseClient
End With
Set rs = New ADODB.Recordset 'Creates record set
strSQL = "<Your SQL Here>"
rs.Open strSQL, cn, strDBCursorType, strDBLockType, strDBOptions
if rs.Eof then
Goto ExitSub
else
For b = 0 To rs.RecordCount -1
'<do whatever you need to do with the data here>
Next b
end if
ExitSub:
rs.Close
Set rs = Nothing
cn.Close
Set cn = Nothing
On Error GoTo 0
Exit Sub
Command1_Click_Error:
MsgBox "Error " & Err.Number & " (" & Err.Description & ")" & _
"in procedure Command1_Click of Form " & Me.Name
End Sub
Private Function ConnectString() As String
Dim strServerName as String
Dim strDatabaseName as string
Dim strUserName as string
Dim strPassword as string
'Change to IP Address if not on local machine
'Make sure that you give permission to log into the
'server from this address
'See Adding New User Accounts to MySQL
'Make sure that you d/l and install the MySQL Connector/ODBC 3.51 Driver
strServerName = "localhost"
strDatabaseName = "DatabaseName"
strUserName = "UserName"
strPassword ="Password"
ConnectString = "DRIVER={MySQL ODBC 3.51 Driver};" & _
"SERVER=" & strServerName & _
";DATABASE=" & strDatabaseName & ";" & _
"USER=" & strUserName & _
";PASSWORD=" & strPassword & _
";OPTION=3;"
End Function
B. Morse
