Hi all,
Kindly tell me why Pull up resistor is needed in microcontroller?
Hi,Pullup or pulldown resitor is needed all the time you make a pin an input, since leaving the input floating will generate unpredictable results, you pull it up so that the value is 1 when switch or sensor connected to that pin is open, will become zero when sensor or switch will ground the pin. Normally a pullup resistor is any value from 10K to 20K.
Alberto
