Pull down resistor value's on a input
ErnieH
Joined Feb 17, 2017
18
Wondering why a pull down resistor value affects a circuit so much, i'm using a pic12f675 with a simple circuit to turn on a led for a few seconds via a micro wave sensor producing a high when movement is detected. When i use any value more than around 470R, it runs the circuit b4 receiving a high from the sensor, e.g. a 1k; 10k, 56k.
It should not be skiping the comand: BTFSS, GPIO,0. I have circuit tied low with a 470R, only now is the circuit stable / not false triggering.
Ernie H.
35,210
You can determine the correct value of pullup/pulldown resistor to use by calculation.
You need to read the device datasheet to find the applicable current and voltage.
For the value of the pulldown resistor, find the logic-low input voltage threshold and the current out of the input pin.
ErnieH
Joined Feb 17, 2017
18
Ernie H.
Thanks 4 all your comments, (it took a while 2 draw the circuit in LTspice) what i'm thinking is happening from a non technical viewpoint is i think its not so much the value of R1, I think the sensor when physically to close to the PIC is creating electrical noise / especially when adjusting the sensitivity to get at least 3m in distance. (the less distance more stable /closer pic can be)
Had similar thing happen with a sensor from RFrobot.
When i put some distance between the two it seems 2 work ok.
Would this be possible?
Thanks.
Ernie H.
boostbuck
Joined Oct 5, 2017
1,064
My first comment is that you should be generous with decoupling capacitors - I don't see any.
Maybe some 100uf across the supply on each board, and some 100n close to the chips.
