greets,
I've got a EPS-112E PSU from a printer and I want to lower its output voltage from 40 to 30V. I found the schematic diagram online (see attachment). There are seven 5.6V zener diodes connected in series in the output stage, is there a reason why they did not use a single 40V zener instead? Could I just remove the zeners and solder in a single 30V z-diode?
Thanks
Thanks
