PSU - Voltage regulation with zener diodes in series ?
prometei
Joined Apr 13, 2008
98
greets,
I've got a EPS-112E PSU from a printer and I want to lower its output voltage from 40 to 30V. I found the schematic diagram online (see attachment). There are seven 5.6V zener diodes connected in series in the output stage, is there a reason why they did not use a single 40V zener instead? Could I just remove the zeners and solder in a single 30V z-diode?
Kjeldgaard
Joined Apr 7, 2016
475
By standard zener diodes, temperature coefficient will be close to zero at voltages of about 6 volts.
In some series zener diodes it's 5.6 volts and 6.2 volt in other series.
Dodgydave
Joined Jun 22, 2012
11,395
dannyf
Joined Sep 13, 2015
2,197
curious as to why they used multiple diodes instead of one...
The zeners are part of the error amplifier. Their primary goal is to detect if the output voltage is over a present threshold. If it is, the zeners start conduct and the led light up.
Using multiple zener here could be for power dissipation: high power zeners ate rare and expensive.
prometei
Joined Apr 13, 2008
98
I would replace the zeners with a Tl431 programmable zener, and adjust the voltage with two resistors to fire the opto-coupler.
Which means that I could make a variable voltage PSU with that, pretty cool.
I was also thinking of just installing a switch that would switch between the zener diodes and change the output voltage in 5.6V increments. The only thing I'm not sure about is the (short) switching period, when the circuit will not get a value from the zener diodes, i.e. as if they were not there, would that be bad for the circuit?
Dodgydave
Joined Jun 22, 2012
11,395
No, as the voltage rises the Tl431 is very fast at conduction, they're use extensively in smps for computers.
You can make it variable with a preset resistor in series with the R1 resistor.
