Hello, I'm fairly new to building psu's and I encountered a problem - thermal resistance/power dissipation to be exact.
I was trying to build a lm338 psu, that would output from 1.25v to 30v dc (I would mainly use 24v as I want to use this psu for an audio amplifier) and I thought a small 35x35x10mm fin plate radiator would be enough (oh boy was I wrong). Luckily, I decided to read up on the thermal problems before building it. So, I have few questions, but first I'll give you some specs:
I have a 230v-24v toroidal transformer that can output around 6 amps, some p1000 diodes,
1x 50v6800uF, 2x50v 4700uF, lot of 100nF caps, lm338 (I also have some lm317t) and other basic components like resistors.
I tried to calculate power loss on lm338 and picked the worst case scenario values, and here is my first question:
When calculating power loss what value should I put in for Vin?
Should it be the rms value - 24v, 33v - peak amplitude voltage 24*√2, or somewhere in between? (my guess is the 3rd option as the capacitors wont charge and discharge at exactly 33v but im not 100% sure)
I hope it makes sense
I used 33v as the worst case scenario, just in case.
Here are my calculations: (33-1.25)*6A = 190,5W
I thought to myself, wow, there is something wrong here, but I decided to calculate maximum power dissipation of lm338 anyway.
125°C - Maximum operating temperature
30°C - Ambient temperature
0,7°C/W - Junction to case thermal resistance (wasnt sure if i used the right one)
2°C/W - Case to radiator thermal resistance (I just assumed this one)
6°C/W - Thermal resistance of the radiator
(125-30)/(0,7+6+2)= 11W
Oh hell no, something is wrong here - I decided to look up some radiators that will be small enough to fit my case
but be big enough to dissipate more heat. The best one I found was a 1.6°C/W one.
(125-30)/(0,7+1,6+2) = 22W - still too small
Decided to stick to the 24v-30v:
(33-24)*6=54W - still too much power.
Lm338 wasnt an option anymore so I took a look at the lm317t pdf and calculated this:
5°C/W - Junction to case thermal resistance (wasnt sure if i used the right one)
1.6°C/W - Thermal resistance of the radiator
1.5A - Maximum output current
(33-1.25)*1.5 = 47,6W (already assumed its too big)
(33-24)*1.5 = 13.5W (seems promising)
(125-30)/(5+2+1.6) = 11,04W :c
A sudden thought went through my mind:
-What if I'm calculating this the wrong way? (english isnt my first language but I tried learning about thermal resistances from english articles, so maybe I interpreted something wrong.)
So that's the second question, am I calculating this right?
And the last question is, do you recommend any other voltage regulators?
Maybe there's a better alternative that I haven't heard about, one with 5A output would be great (but probably
unachievable with my current radiator, right?) - it can also be 3A/2A/1.5A - but I feel like I'm wasting the potential of my transformer using a 1.5A one.
I hope that some of you are willing to help and everything I wrote is understandable to some extent
Thanks!
Thanks!
