One troubleshooting technique I use is to assume that EVERY wire and component is miswired. Then one by one, I prove myself wrong. I use a schematic and highlight every component as I complete checking it.I had multiple ground wires and one of them accidentally got placed on a + rail.
There may be some ripple on the output of the buck regulator.I have tried adding film caps after the buck controller from .1uF to 10uF and the pattern continues.
I actually do. I have been scared to use it with an A/C circuit because of the warnings I seen (including yours) about ground loops(?) Can I use it safely? IF so, how?Do you have an oscilloscope?
If you rearrange the blocks in your schematic, you can avoid that big backtrack and wire crossing.
The lessons keep on coming!! Thanks!If you're using connection dots, you don't need to break wires that cross. With the connection dot style, crossing wires don't connect without a dot. It's okay to have multiple ground symbols to avoid wire crossings.
The ground loops reference must have been for some higher speed signals (10MHz square wave?).I actually do. I have been scared to use it with an A/C circuit because of the warnings I seen (including yours) about ground loops(?) Can I use it safely? IF so, how?
Some can't take constructive criticism. You have the right attitude for learning.The lessons keep on coming!! Thanks!
My scope is Sigilent SDS 1052DL so it is 110V-powered. Can I still use it somehow?If you're on the secondary side of the transformer, all of the voltages are considered non-lethal (below 50V). If you have a DSO138 and the power source is isolated from line neutral/earth ground, you can put the ground lead anywhere you want because scope ground would be floating with respect to earth ground. This isn't the case for line powered scopes that will usually have ground connected to earth ground (for safety).
Yes. With line powered scopes, the ground clip is earth ground, so care must be taken when you're measuring things that aren't isolated from earth ground.My scope is Sigilent SDS 1052DL so it is 110V-powered. Can I still use it somehow?
It seems strange that the trace would make a jump in the middle of the sampling.This is what I see. I don't know how to interpret it.
I was using a filtering cap in the first pic. I tried it with values from.1uF ro 10uF. All the outputs look similar. Note that I changed the time to 25.0ms.It looks like switching noise to me. Do you have the recommended filtering on the output?
That's kind of a low frequency for switching noise. Is the ripple causing any problems? If it is, you could try a larger filter cap.I was using a filtering cap in the first pic. I tried it with values from.1uF ro 10uF. All the outputs look similar. Note that I changed the time to 25.0ms.
I haven't tried to do anything with it so far (other than try to measure the output) so I don't know. But the first thing I hoped to do with it was top balance $600 worth of LiFePO4 batteries so I don't want to experiment with those.Is the ripple causing any problems?
All caps were ceramic. I have larger electrolytics, though.I assume the 10uF cap was electrolytic. Was the 0.1uF ceramic?
I'm not sure how I would do this with the buck controller. I have some variable regulators, if that helps. They are LM317T. Thank you for helping me!If very low ripple is needed, the basic power supply can be used to feed a three-terminal voltage regulator IС, which can easily reduce the ripple by a factor of 60 dB or so at low cost.
Are you using an approved charger? Lithium batteries don't like to be abused. batteryuniversity.com should have information for them.But the first thing I hoped to do with it was top balance $600 worth of LiFePO4 batteries so I don't want to experiment with those.
I've never seen a ceramic larger than 2.2uF. The filter caps are typically aluminum or tantalum electrolytics. Smaller value ceramics are used to filter higher frequency noise.All caps were ceramic. I have larger electrolytics, though.
I have a proper BMS and a really good charger for regular charging when they are wired as 3.2V x 4 = 12.8V serial. and charging from solar panels. What my folks in the battery world (and the BMS manufacturer are suggesting is that I start by top balancing them wired as a 280aH parallel wired pack (3.2V). According to them, as long as I have a steady 3.6V to 3.65V and no more than .5C charging (10A would only be .1C), I can use any quality charger. I'm hoping I have a quality charger when this is all said and done....Are you using an approved charger? Lithium batteries don't like to be abused. batteryuniversity.com should have information for them.
I hesitate to say I got an assortment of ceramic 50V capacitors (.1uF to 10uF) from Aliexpress. So..... bigger is not always better. IF you can suggest a size and type cap, I will certainly buy it and try it.I've never seen a ceramic larger than 2.2uF. The filter caps are typically aluminum or tantalum electrolytics. Smaller value ceramics are used to filter higher frequency noise.
I usually go for 470uF or 680uF electrolytics for supply filtering because I happen to have hundreds of them on hand.I hesitate to say I got an assortment of ceramic 50V capacitors (.1uF to 10uF) from Aliexpress. So..... bigger is not always better. IF you can suggest a size and type cap, I will certainly buy it and try it.
Oh... I'll try these sizes. I have some. This is magnitudes larger than the ceramics I was using.I usually go for 470uF or 680uF electrolytics for supply filtering because I happen to have hundreds of them on hand.
I haven't had any bad experiences yet. I also assumed most tiems sold in the US were imported from Asia anyway. But I suppose reputable companies (e.g. Mouser) have reputable sourcing unlike Aliexpress. Are things like transistors, capacitors, resistors and diodes usually counterfeited?Some stuff is junk, but I'm not out too much money when I find a particularly disreputable seller.
They counterfeit just about everything. Even surface mount ceramic capacitors that sell for less than half a cent. Chinese resistors tend to have skinny leads (andAre things like transistors, capacitors, resistors and diodes usually counterfeited?
