PSU Question - (Newbie)
CCinBR200
Joined Oct 4, 2020
80
If the terminal numbers correspond to the datasheet, 1=base, 2=collector, 3=emitter; the base emitter junction looks like it's shorted. Don't see how the collector voltage could be lower than the emitter.
Are you certain of the terminals and connections?
I thought I had posted a reply last Friday with thanks but it didn't post. I had gotten the pinout wrong on the 2N3904. With it wired right, I get 14.4V after the TIP31C. Hooray!IMG_20201211_085448411.jpg
But, when I add the remainder of the circuit the voltage drops at the TIP31C to .66V.
It's also .66V at leg 1 (input) of the L7809CV.
I'm stumped again.
dl324
Joined Mar 30, 2015
18,521
It would be helpful if you posted the relevant part of your circuit.
What are the voltages on the TIP31C terminals? What is the voltage and current capability of your power source?
CCinBR200
Joined Oct 4, 2020
80
I tried a couple of experiments:
- no L7809CV
- only .1uF cap after the L7809CV
- a .22uF cap before the L7809CV and the .1 uF cap after
Results:
no L7809CV .1uF cap .1uF + .22uF caps
TIP31C base 15.01V 15.33V .65V
TIP31C collector 41.3V 41.1V 38.7V
TIP31C emitter 15.05V 15.36V .65V
L7809CV Input N/A 15.36V .65V
L7809CV Output N/A 0V 0V
I thought about the dropout voltage (2V). That's why I went 9V instead of 12V. So the input voltage should be sufficient for the L7809CV.
What am I missing?
Carlo
dl324
Joined Mar 30, 2015
18,521
You must have something wired wrong - and your data is incredibly difficult to read.
Take the measurements with everything in the circuit. You only have a half dozen components and it won't be difficult to see what's not working.
EDIT: and put a 20mA load on the regulator. The regulator isn't guaranteed to work with little or no load.
CCinBR200
Joined Oct 4, 2020
80
Sorry for the hard-to-read data. I had everything lined up but I guess AAC compacts things. I ran out of time today before the workshop closed. I'll take these suggestions and get back next Friday. As always, thanks for your time and expertise!
Carlo
CCinBR200
Joined Oct 4, 2020
80
Hello again and Happy Friday! I took the whole circuit apart and carefully redid it.
I put a 680ohm resistor on the end as I calculated 20mA load to be R = 14V/.02 = 700ohm.
I get the following:
without a load:
into circuit: 38V
at TIP31C Emitter: 17.5V - so far so good
with the load:
into circuit: 39V
at TIP31C Emitter: .6V
L7809cv Input: .6V
L7809CV Output: 0V
Stumped again.
Carlo
dl324
Joined Mar 30, 2015
18,521
with the load:
into circuit: 39V
L7809cv Input: .6V
L7809CV Output: 0V
That doesn't make sense. The transistors and zener can't drop more than about 11.5V.
What are the voltages on the bases of the transistors?
EDIT:
BTW, the 151 ohm resistor can be an eighth or quarter watt.
\(P = \frac{V^2}{R} = \frac{1.4V*1.4V}{151\Omega} = 13mW\)
CCinBR200
Joined Oct 4, 2020
80
2N3904 Base = .6V (stable)
TIP31C Base = not stable but fluctuating around about .6V to 1V
I am attaching a drawing of how my wires are actually running in case there's an obvious error there.
EDIT:
Thanks! I'll work on calculating the amps (I also have more 1W than 1/4W supplies).PSU 12.18.20 - 2.JPG
LesJones
Joined Jan 8, 2017
4,544
Which is the schematic have you actually built ? The one in post #63 or the one in post #66 ? #63 should work. In #66 the two transistors and the resistor serve no purpose as the resistor is shorted out.
Les.
dl324
Joined Mar 30, 2015
18,521
The voltages don't make sense. Do you have a cap on the output of the regulator? That helps with transient response (another way of saying oscillations).
Black text are your measured voltages. Red are the expected voltages.
CCinBR200
Joined Oct 4, 2020
80
I built #66. To the best of my (very humble) understanding, it is the circuit suggested in #50 plus the resistor load (20mA) suggested in 50.
Les.
I did in an earlier iteration. I removed it for the most recent versions hoping that simplifying the circuit would help me find the problem. (I know this is probably very ignorant logic). I can replace it.
Did my drawing in #68 suggest why I'm so far off?
Thanks to you both.
LesJones
Joined Jan 8, 2017
4,544
I made an error in post #71. I wrote post #66 where I should have wrote #68. The schematic in post #66 should work. From the voltage reading you give on the bases of the transistors I would say that the zener diode is open circuit. I agree with the voltages that Dennis has calculated.
Les.
dl324
Joined Mar 30, 2015
18,521
Nothing you've posted gives any clue why you're measuring 0.6V on the emitter of the TIP31C.
If the zener was open, you'd should see about 38V due to the leakage current in the TIP31C which should be less than 0.3mA.
CCinBR200
Joined Oct 4, 2020
80
Hooray!! It turns out that I must have destroyed the zener with one of my screw-ups experiments. The interior was black and burnt (like my soul). I now have stable 9V coming out of the L7809CV. Another hurdle over!
So I attached the fan and it runs for one second and stops. I'm guessing I have something wrong or missing with capacitors. It will do it over and over so I didn't burn up the fan.
The output of the L7809CV is as follows:
- without the fan attached: 9.0V
- attach fan: drops immediately to 3.3V
I am attaching my new complete project schematic.
Thanks!
dl324
Joined Mar 30, 2015
18,521
On top of all my other flaws is bad handwriting. That should read .30A.
Putting the customary zero in front of the decimal point might have caused it to be read it as 0.3A.
The voltage regulator seems to be current limiting, but it's rated for 1.5A with sufficient heatsinking.
