pspice switch
Matherios
Joined Feb 25, 2018
74
I have a homework to do a simulation of a curcuit which needs the switch on and off.
My question is there any difference to all the switches that the pspice(capture cis) has between them and also how do i turn on and off the switch on pspice.switch.png
Jony130
Joined Feb 17, 2009
5,598
You can try to use Sw_tClose and Sw_tOpen connected in series or instead of a switch you could use VPULSE source (squarewave).
Also, what are the purpose of a logic gate and R2 resistor?
Matherios
Joined Feb 25, 2018
74
I found the switches but in the end i just used a big resistance for off state.
The nand is used as a (not) and the R2 is used in case we remove the nand or it get's destroyed we will be sure we will have 0 volts on the mosfet.
