ps3 fan connector how to fix tracks?
Shisui
Joined Dec 16, 2020
I broke the connector. I watched videos on youtube. They exposed the copper and soldered again. How do I know if it is correct? do I have to do it another way? I am interested in knowing how to see that the voltage will arrive and what is the way to solder the connector If anyone can help me thanks IMG20.jpg
twohats
Joined Oct 28, 2015
618
More info. please.
What is the item/unit? EDIT: PS3, I guess that's Playstation3 (Older generation).
What is the connector?
Shisui
Joined Dec 16, 2020
ps3 fat
This is the connector
As seen in the picture I had to scratch to get to the copper But I don't know if I solder the connector, how can I know if voltage will arrive?
twohats
Joined Oct 28, 2015
618
First solder the tracks where you've been scratching, they should be nice and shiny, this is called tinning.(Look on YouTube for soldering). Do the same with the plug. then solder the two together.
How did you manage to break it?
Good luck............
Shisui
Joined Dec 16, 2020
How do I know if voltage will arrive? How can I use a multimeter to see if there is voltage in the welding?
