Provide Volt to Microcontroller for powerup device
TheDag
Joined Jan 1, 2010
94
I Have bluetooth headset, I Want to turn it on automaticlly....
the steps for power up the device is:
Click the button for 5 seconds and the device power up!
I Know i should use LM555 in this case...
I Have some tests, and all I need is provide some volts from the 1 switch pad, To the other switch pad(Microcontroller) for 5 seconds
Thanks in advance
hspalm
Joined Feb 17, 2010
201
You can use the one-shot monostable configuration of a 555 timer. But have you thought of that you now need another button or signal of some sort to trigger the 555? At least you don't have to push the button or provide signal for 5 seconds anymore. http://www.kpsec.freeuk.com/555timer.htm#monostable
Since your microcontroller needs "volt" at the input (you're sure?) you can probably just hook the 555 output straight to the uC input pin from the old switch /whops, remember no higher voltages than uC is running at), might want to put a 1k series resistor on for safety. If you find out the switch was rather pulling the uC pin to ground, you need to invert the signal i.e. with an NPN transistor pulling the pin to ground.
hspalm
Joined Feb 17, 2010
201
If you wire up a 555 timer in monostable configuration correctly, then it will output a pulse of the duration you desire when you trigger it by a high level or short pulse. Look at the link I posted.
hspalm
Joined Feb 17, 2010
201
You must connect the 555 to 12v? The circuits on that site are only examples, the 555 goes down to 5v I think, then you can just cheat by putting a resistor divider on the output.
hspalm
Joined Feb 17, 2010
201
I know many people do this with TTL serial communications when interfacing 5v devices to 3.3v devices. But I also know the technique is not approved by everyone on this forum, don't remember why.
edit: by the way, you don't want to use the 3.7 volt, this is at battery maximum charged level. When battery level drops below this, you don't want to put a voltage on the microcontroller pin which is higher than its VCC. If you know which microcontroller it is you can check its datasheet for minimum input low voltage, Vil (min)
