I was working on a project where I need to solder a BGA (0.8mm pitch). I have previously hand soldered SMD components like QFP, QFN but never a BGA.
I was reading about BGA routing and why it's a bad idea to place vias under BGA pad (solder gets sucked into pad via capillary action).
That got me thinking, while this is a problem for a mass produced reflow design, could this be leveraged for easier BGA prototyping (without having to use reflow/stencils).
Basically place a PTH on every BGA pad, smaller than the pad. Now the BGA can be placed and centered on the pads (the balls will sit on the holes).
Now flip the board around (while maintaining BGA location), and feed in solder from the back side into every hole (agree this is time consuming for 400 holes, but not a deal breaker).
I have previously soldered the QFN thermal pad with this technique. I tried to look up a lot, but didn't find anyone using this. And there's the universal wisdom that PTH under BGA pad is a bad idea.
What am I missing here?
Thanks,
Sagar
Thanks,
Sagar
