Prototype board layout software?
bignobody
Joined Jan 21, 2020
97
I'm still a beginner at building circuits. I am getting to the point where I am starting to use several integrated circuits, and with more ICs comes more complex layouts when it comes to actually soldering things together on a prototype board.
I've been drawing layouts on paper and moving sockets around on prototype board until now, but I have a software background so it's natural for me to wonder if a computer could help me with this.
What I am imagining is a prototype board display that would allow me to add ICs of different pin sizes to it, select which pins connect to what, and then allow some configurable algorithm to try and fit everything nicely into that space with sensible paths for the requested connections.
Before I go off half-cocked and try and make something myself, does such a thing exist already?
SamR
Joined Mar 19, 2019
5,535
Sounds like Fritz but I wouldn't recommend it. There are several PCB design software apps but that is not for protoboard layout. I just do it by the seat of my pants. Layout the devices on the protoboard and when satisfied start soldering. I typically work from a schematic and breadboard it before going to a protoboard to test it out.
bignobody
Joined Jan 21, 2020
97
Thanks for you reply, SamR! I recall seeing Fritz in a software list somewhere, but yeah, most of the software I've seen so far seem to be for layout out of PCB designs rather that through-hole protoboard... I'm not ready for that yet.
"Layout the devices on the protoboard and when satisfied start soldering" is where I am at. It's not bad, but I still wonder if it could be better.
dl324
Joined Mar 30, 2015
18,454
Most schematic editors include a PCB layout program with an autorouter. I use Eagle, but not the autorouter. I can always do a better job routing manually.
Even if you're using strip board, you can use a more general program to do the layout.
jpanhalt
Joined Jan 18, 2008
11,087
I use Eagle for routing breadboards. It can be used for both solderless and solderable types. If the project is at all complex, I generally use solderable, and by extension, only simple stuff goes to solderless.
The one big advantage of Eagle over Fritzing and other programs that are available is schematic capture and ease of moving stuff around.
Here's an example from a recent project. I turned grid off. It is set to 0.1" to correspond the the SparkFun solderable breadboard:
On free versions, you are limited to 2 signal layers. Make up your own rules. On some boards, I use blue for existing tracks, and red for wires I add. I used a white dash to indicate need to cut an existing track. If you print black on white with a grid, you can just count spaces to know how long to cut the wires. I use Kynar-insulated 24 awg solid wire. The Kynar withstands considerable heat and doesn't get burned or melt like PVC does.
dl324
Joined Mar 30, 2015
18,454
Here's an example of a layout I did for 4 discrete clocked R#S# flip flops that's part of a clock project. I intend to make some boards, but hand wired the first for testing. The board I used had space for 6 flip flops, so I adapted the layout on-the-fly to add 2 more.
Thanks for the input, everyone! Much appreciated. I'll have a look at these suggestions.
I second using Eagle (or equivalent) for breadboards. I use it too. The extra time to learn the very high level ultra-expensive software (there are still free versions) pays off in ways you can't imagine now. The ability to take something like this.
PIC32MX250 and two 45K80 controllers.
directly into a easily manufactured PCB consistent with the working prototype electrical schematic is priceless.
ErnieM
Joined Apr 24, 2011
8,415
ExpressPCB is a company that is in the prototype market. Their free software allows you to start without a schematic and just try things out. Should you layout a schematic first you can link them and see what connects to where. The output is limited to a paper copy unless you actually order boards from them. I like their software a lot as it can make a quick and dirty laydown very fast.
For a "real" design Kicad is hard to beat. It is completely free and unencumbered by any artificial limitations. However, it has as steep a learning curve as any full featured program, meaning you must create a complete schematic by their rules, assign a package to each part, then load the netlist (connections and packages) to the PCB layout program.
Sensacell
Joined Jun 19, 2012
3,787
For breadboarding- I see layout software as additional work that produces no value.
Capturing the schematic is very valuable- and speeds the rest of the process, but whacking together a breadboard is very different from laying out a PCB.
The goals are very different.
Breadboard = design validation.
Make it easy to change.
Make it modular, so you can test circuit blocks independent of others
Make it easy to test- connect test equipment.
bignobody
Joined Jan 21, 2020
97
This post got necro'd a little, but more discussion on the topic is always welcome!
Since I originally posted this I fumbled my way through learning Eagle enough to have a board manufactured.
This was recommended in another thread and I'm learning it now with plans to build my second pcb with it. Still a work in progress, but I'm pretty impressed with this software so far. And no subscriptions necessary :)
bignobody
Joined Jan 21, 2020
97
My initial reaction was this felt a bit harsh. Then I thought about it for a minute and I found I can't actually disagree with your assessment. Yeah, I'd really just rather have a go at a real breadboard with real components.
I haven't seen the actual software, though, so maybe there's some value that's not readily apparent.
ErnieM
Joined Apr 24, 2011
8,415
I must disagree here. Sure, if everything comes together you may plow thru the entire build/debug phase with no muss no fuss and no interruptions... or not.
Being blessed with Autocad I start with the layout of my favorite breadboard and then overlay it with all my parts and reference designations. You could use anything for this, like Visio or even MSPaint. This is mostly a copy and paste operation, and if I cme back to something after weeks (or years: it has happened) I know exactly what I am looking at.
