I'm trying to use atmega32 tqfp in proteus .
ports numbers are normal in DIP mode but does not change when i change PCB package to TQFP. so port numbers would be wrong if i use TQFP .
I checked it for atemga8 and atmega16 ,both were correct ,so only atemga32 has this issue.
for example port 14 is RXD in DIP mode , but for TQFP proteus also shows this port as RXD , that is wrong.
I'm running proteus 8.6 sp2 build 23525
