If a device runs at 3.3v 0.30 mA peak how do you protect it? What fuse would you use?
It sais 250v though.The Fast Blow 5x20 Glass Fuse comes in 30ma size
https://www.amazon.com/uxcell-Quick-Glass-5x20mm-0-03A/dp/B00X7BD53I
Yes, that's the maximum circuit voltage for its use.Does that mean 250V max?
Can I apply this to a 3.3V circuit?
Thank you,Yes, that's the maximum circuit voltage for its use.
There is no minimum voltage.
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
