Protect TIA
Eartian
Joined Sep 16, 2021
58
I am about to build an TIA with LMP7721. Since it's operating voltage is only 0 to 5v, how can I protect it from sudden large voltages? this TIA basically is being used in potentiostat I am building. The TIA is placed at near to GND, that means current is being sensed at the lower end. The protection circuit should not leak current as the potentiosat may need to work in nano amps range too. So any suggestions please? the maximum sudden voltage may appear can be upto +or-12v
KeithWalker
Joined Jul 10, 2017
3,613
A transient ischemic attack (TIA) is a “warning stroke” that can cause sudden symptoms such as weakness, speech problems. Are you really going to build one?
Ian0
Joined Aug 7, 2020
13,210
As the input is directly to the inverting input of the amplifier, the signal should only come from something that is a current-source, or current limited, and there should be no voltage change on the input. Therefore clamp with two back-to-back schottkies to ground (or to whatever the non-inverting input is connected to)
Don't forget that if the non-inverting input is connected to ground, the circuit can only sense negative currents.
