Projector Specification?
biferi
Joined Apr 14, 2017
529
Ok I Converted 2. Movies to MP4. H264 Videos 2. Minutes Long.
They are the same thing but one Video File I Set the Video Bit Rate to 512 kbps and the other Video File I Set the Video Bit Rate to 5,000 kbps.
I Made them Both 2. Minutes Long but this Site will not let Me Upload the Files.
I put Both Video Files into MediaInfo and Uploaded the Data Text File.
Can You please take a Look at the Media Text Files to See why My JimTab M18 Pro. Projector only Play Videos with a Video Bit Rate of 512 kbps?
This is very very Low and JimTab Tells Me it should not Play it it should Play the 5,000 kbps.
biferi
Joined Apr 14, 2017
529
I Know now that Projectors give an ASNI Rating for how Bright the Lamp Output is.
I Watched one Video that Says Projectors are Rated in Anti Lumans.
If I google Anti Luman I Find nothing on it.
Can anybody help?
DickCappels
Joined Aug 21, 2008
10,661
You probably did not find anything because it should be spelled ANSI Lumens
A Lumen is the total amount of light that gets out of the light source and can be used to illuminate something. As with seemingly simple looking things, measuring it can be very involved.
biferi
Joined Apr 14, 2017
529
Google was Switching it to ANSI Lumens but I Thought the People on YouTube are Saying Anti Luman LOL.
So I did Find out 1,000 Lumans is 400 ANSI Lumens.
If I am Understanding thing more the Luman Rating is just the Total amount of Lumans that the Whole Lamp Outputs.
ANSI Lumens Meter is used like this.
They Hold an ANSI Lumens Meter on the Screen at Say the Top Left Side.
Then the Movie it to Say 3. other Spots.
Because as the Light comes from the Lamp it goes through the Room so it may be Dimm at other Parts of the Screen.
So they do a Math Formula for the Spots they had the Meter on.
Am I Right or am I still not Understanding it?
Thanks for the Time.
DickCappels
Joined Aug 21, 2008
10,661
The word is Lumen. Your other variations ate not the same. I sympathize because for many years I would spell in "Lumin" which is something completely different. L-u-m-e-n. Nothing else. :)
biferi
Joined Apr 14, 2017
529
I did get the JimTab M18 Pro. Projector.
It was working good till now.
I Converted a Movie to MPEG2. and Left Frame Size and everything Same as Source.
I only Changed Bit Rate to 512 Bit Rate and then I did one with 1500 Bit Rate.
The Movie Plays but is Freezing every 5. Seconds then Plays ok and does this Off and On.
And it does this with Bth Videos and well as My Wireless Roku Plu Stick if I Watch NetFlix or YouTube.
I did Un Plug it for a Long Time and it still happens.
I Know it was only $200 USA but should Play ok.
Is there any way to Delete the Projectors Buffer or what?
