You'll have to use your googler for that.I did like the Vankyo Leisure 510.
It Says the LUX is 3,600
Can You Tell Me what the RES. is for this and the Contrast Ratio?
Thanks for the Time.
If the lamp really lasts 100,000 hours (which I somewhat doubt) which is 11 years of continuous 24-hour/day use, then you shouldn't have to replace it in your lifetime.I am Looking at this Projector.
https://www.amazon.com/TENKER-Bluetooth-Projector-Portable-Compatible/dp/B09F9M3NST/ref=sr_1_1_sspa?crid=1NM9B8Q13SPT9&keywords=vankyo+leisure+510PW&qid=1640633408&sprefix=vankyo+leisure+510pw,aps,187&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFWWExHWjcyN1RLMzcmZW5jcnlwdGVkSWQ9QTA3MzI1MDQzSDkxWkZGSVExUjZCJmVuY3J5cHRlZEFkSWQ9QTA2OTc3MjQ1NkFCTTRWN0lWSUImd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Do they make one that You can Replace the Lamp after it Burns Out?
This one You have to Send it in for them to do it.
I would think just about any other name-brand projector with a lamp can have it replaced by the owner.Can anoybody give Me a Name of a Projector that will let Me Replace the Lamp?
That's not JVC, it's a DBPOWER 8000L, an unknown brand to me.I found this JVC Projector.
Why do you keep repeating the definition of a mostly obsolete type of projector?A projector is an instrument used top produce a large image of a small object. The slide, or film, is placed behind the projector lens outside its focal length and is illuminated but a small but powerful source of light.
$100 projector is unlikely to have a lamp that costs $600 to replace; I'd guess a $10 halogen bulb. The reasons to get a projector in that price range will be a need for portability and a big picture in a dark room. If that's enough, you may be better off shopping locally for used business presentation projectors. I found a 1024x768 NEC advertised for $60 just now.good Projector for around $ 100
Is your microSD card too slow to support thst video codec? What, exactly does your SD card say? Not all SDCards are actually just plain old "SD". There are newer, faster, higher capacity sub-formats - SDHC, SDXC, SDUC and read mechanisms of "high speed", UHS-I to UHS-III and Express.I now now about Video CODECs and every one has Different Versions.
I have the JimTab M18 Pro Projector.
I have the DVD "The Dark Crystal" and I Made it into a Format the Projector can Read.
MPEG 4. Format.
H264 CODEC.
720 X 480 Display Size.
29.97 Frame Rate.
1,000 kbps Video Bit Rate.
And My Projector Says Un Supported File.
Now if I keep everything the same but I Make the Video Bit Rate 512 kbps My Projector Plays it.
I E Mailed JimTab and Asked them why the 512 kbps Video Plays?
They Told Me the Video with the Bit Rate of 512 kbps should not Play the Video with the Video Bit Rate of 1,000 kbps is the one that should Play.
They Told Me a Video Bit Rate of 512 kbps is to Low for the Projector to Play.
Can anybody help?
It is on a Micro SD Card.
It should be ok.My Card Says it is UHS 3. and it also has the "C" with the Number 10 Inside it for Class 10 it this ok?
