Project Proposal.
R!f@@
Joined Apr 2, 2009
10,007
My first time doing this.
I like to know how you would do a proposal to a project that you made.
It's the controller I have been working on. Several threads are here. Lot of issues like SMS and IRP bit problems have been solved by the members.
I have done the test on prototype on customer site and I need to do a proposal on it.
Like to see some examples and advice on what should be included and what not.
Regards
Rifaa
GopherT
Joined Nov 23, 2012
8,009
Regards
Rifaa
I've used the concept that it is essentially a request for proposals (rfp) in reverse which also follows a much more common request for quotes (rfq). Use the same format of the more common rfq and rfp but word it as a push for the project instead of a request for a solution or a request for quote.
I cannot share anything but search rfq and rfq for examples.
ericgibbs
Joined Jan 29, 2010
21,513
hi R!f,
This PDF is one option.
If you require a wider range of options.
Google: writing a project proposal
Eric
BTW:
I would advise you to make it clear to the 'proposed' client that the 'proposal' is your intellectual property and must not be redistributed without your written permission.
One pitfall I have seen many times, is that the client will invite others to submit tenders based on your written proposal.
R!f@@
Joined Apr 2, 2009
10,007
Thank you Eric. :)
Any one else ?
I am looking for members who might have first hand experience to guide me for a kick ass one :D
I did not make this from a written request but rather from employee who want something that can do this and that and all that. So it evolved to what I have made. This was better than what they did and exceeds their expectation.
