Project Parts Research
Georacer
Joined Nov 25, 2009
5,182
Apparently I am. I just checked the edit dates. It's of yesterday.
I 'll stick it anyway.
Good job in a job well done, which has already helped me tremendously. Thank you very, very much. You and all the people who contributed to it.
Georacer
Joined Nov 25, 2009
5,182
The nalanda site, which contains the NatSemi app notes, is on and off, periodically. I fear for its longevity.
Maybe the pdfs should be stored locally while the site is still up.
Wendy
Joined Mar 24, 2008
23,797
Funny thing, I fully plan on using the list, but I will probably modify it for myself to match my tastes.
I haven't looked lately, logic level MOSFETs covered?
Wendy
Joined Mar 24, 2008
23,797
Any chance the sticky will return? We can always modify it later, and it could be of some use now.
I think linking the part numbers to online data sheets would be a worthwhile endeavor, but not worth holding things up over.
I consider this the master thread, where we can discuss changes on the long term.
34,890
Logic level MOSFETs are becoming popular choices in MCU controller applications.
What are common components that folks are using that I may add to the list?
Also for motor H-bridge drivers, what low-side and high-side MOSFETs are being used?
Georacer
Joined Nov 25, 2009
5,182
I hadn't visited this thread in a long time, and I don't remember when the footprints tables for the 3-pin elements was introduced, but it is very helpful.
Thanks.
Rbeckett
Joined Sep 3, 2010
208
Mr Chips,
Thank you for such a complete and thorough listing of the most common parts and there common uses. Makes part selection a bit easier, even if you happen to need a slightly different spec or voltage. Great series.
Bob
34,890
You're welcome, Bob.
But I thought that what you are asking for is a list of parts that are required specifically for the AAC Lessons.
Georacer
Joined Nov 25, 2009
5,182
Does anyone know the difference between the LT1086 regulator and the LM counterpart?
The numbers don't tell a complete story.
