Programming sensors
man111111
Joined Mar 15, 2020
9
This is my first ever post :)
I'm currently looking into programming a humidity sensor. I have been given the impedance vs RH% graph on the data sheet. However, I would like some advice on how I should go about programming the humidity sensor.
djsfantasi
Joined Apr 11, 2010
9,237
Wait a minute... what are you programming? What sensor are you using? Is it even programmable?
I have dozens of questions. Let’s start with those three?
man111111
Joined Mar 15, 2020
9
hcz j38 Is the name of it but have no idea how to use it so that I can record the humidity.
djsfantasi
Joined Apr 11, 2010
9,237
I searched for “hcz j38” and couldn’t find anything. So let me tell you a hint. When you have the right part number, type it into the search bar and add “ Arduino” after it. You’ll usually get sample code, typical circuits and maybe even a library you can download.
atferrari
Joined Jan 6, 2004
5,029
Show a picture of the sensor so we can read the ID.
Humidity sensor Multicomp HCZ J3B, most probably.
I suggest you to start furiously to search the datasheet. Do not be lazy.
man111111
Joined Mar 15, 2020
9
Hi, I looked at the datasheet but it doesn't mention how I can use it with a LCD. I'm not sure how I should use the impedance vs %RH graph to help me...
OBW0549
Joined Mar 2, 2015
3,565
Of course it doesn't. Why in the world would it? It's just a sensor, not a complete sensing/processing/displaying system. If you want to display humidity on an LCD, you're going to have to figure out how to do that on your own. It will involve not only the sensor, but signal conditioning circuitry, a processor (e.g., an Arduino), and the LCD as well-- plus a lot of programming of the processor to convert raw measurements into displayable results.
If it doesn't, you're going to have to do a LOT of learning before you can use this sensor.
This sensor operates with AC excitation (1.0 volt MAX, 0.5 ro 2.0 kHz) and will require some very specialized circuitry to convert its impedance to a DC voltage that can be read by an Arduino or other processor having an analog to digital converter. Designing such a circuit is not-- repeat NOT-- a task for a beginner and is not a very easy task even for an experienced designer.
Based on your questions, and having looked at the sensor data sheet, I have to say that it looks to me like you're in way, WAY over your head with this thing. It would be best, for the sake of avoiding enormous confusion and disappointment, to start with a simpler project.
Sorry, but that's the way I see it.
(The data sheet I looked at was here.)
ci139
Joined Jul 11, 2016
2,034
That link consistently brings me to a malware site.
if you call Google Search - Wikipedia such . . . i have noticed the trend lately , that at the end of results list there is a higher concentration of "irrelevant" or commercial links (applies to more general search terms) -- some of which may pose potential hazards if you don't close them and click where it happens . . . sorry to say but i assume the members here have a brain and know how to get around in www
SamR
Joined Mar 19, 2019
5,538
Two things, how to connect to the LCD, then how to write to the LCD. Good LCDs should have a 2 wire connection otherwise it will take a LOT of pins. Depending on the type of LCD (graphic or digital) you may also have to learn the code for the graphics.
atferrari
Joined Jan 6, 2004
5,029
I have no idea what you know about all this but I was about to comment in line with what OBW0549 told you.
Once you have learnt how to measure the output from the sensor, you need to process it and then display the numerical value somewhere.
My first complete design was something very similar: a temperature data collector for a green house managed by a small microprocessor.
I climbed up the whole ladder learning about the sensors up to the display and, of course, programming the micro as well.
My suggestion: resist the temptation to come every minute to ask questions in a forum. Do your effort while you practice with the real hardware. Come to a forum for specific doubts that you honestly cannot solve. Buena suerte.
I am done.
35,199
Chill out fellas. This is a new member who is just getting his/her feet wet.
The datasheet for HCZ-J3 is available here.
Now you need a system that will measure impedance and temperature.
How much experience do you have to tackle this?
man111111
Joined Mar 15, 2020
9
I've only been studying electronics for about 8 months by reading books and watching YouTube videos and decided that I wanted to make my next project using a humidity sensor.
I've programmed a few stuff using microcontrollers and I've made some stuff using opamps, resistors, transistors and LDRs... but havnt worked with capacitors but have studied them.
I've also studied the transistors inside opamps
jpanhalt
Joined Jan 18, 2008
11,087
If a program is not given on the Arduino site, do you have experience writing microcontroller (MCU) code? What language? Do you know how to use a look-up table or do an approximation of that line? You will also need to measure temperature.
You might be able to find a probe that has been linearized. You will still need to measure temperature, unless it includes that too.
This is an example of an integrated temperature and humidity sensor: https://www.maximintegrated.com/en/products/ibutton-one-wire/data-loggers/DS1923.html
I did not look at the datasheet -- I have to fix dinner first.
man111111
Joined Mar 15, 2020
9
I've studied C,C++ and assembly code. How can I make an approximation line from the graph or use the lookup table provided in the datasheet?
