Programmable Switching Load
beera beer beera beera
Joined Dec 16, 2016
25
Need help on finding programmable Load.
Specification :
Voltage - 3.7V to 15V
current - 10A
Switching frequency - upto 5KHz
Anybody can suggest near to or above spec sheet (higher voltage , current ,frequency).
For example I want to test 5V , 6A adapter for our application , load should be 0.833 Ohm , 500uS on , 15uS off (98% duty cycle)
Srinivas
Alec_t
Joined Sep 17, 2013
15,167
The thread concerns a 'programmable load' but the only load example you give is 0.833Ω.
What range of loads/duty-cycles do you need?
What tolerance do you really need (0.833 implies 0.1% and could require expensive components)?
What will do the programming?
ErnieM
Joined Apr 24, 2011
8,415
If you are buying one try Gooole and a google of choices will appear.
If you are uilding one a similar array will appear if you search for schematics.
Which are you doing? Budget? Timeframe?
