LabView is sort of like Matlab: terrible but the best you can get for some things because it is ubiquitous.How you do envision controlling these?
I had envisioned a program I have written here that would trigger the pulses specifying their frequency and duration. It takes an arbitrary input I have here then returning output pulse specifications.
It can be computer controlled, by LabView if you are using it. It has direct entry for all the signal parameters. It does more than you want because it's not a programmable pulse generator but those are usually for very high frequency applications and cost a lot more.
I'm not using LabView so far, I had written my own application that creates the triggers - just nothing to connect it to at the moment; although it appears I can integrate existing code with it so will have a look; thank you.
If you are using LabView than you can look for data acquisition boards that it supports for your recording.
