I am not sure if this is the right place to post, but I see a lot of other discussions on known issues with MC-60.
I have an older (old) treadmill (Spacesave 580i) where the speed pot has simply stopped operating correctly. When I adjust the speed up just a little, the treadmill starts running at full speed with no intermediate setting whatsoever. The speed is set by a slider pot that appears to have a 16k range, up on the user panel. When I take this out and test it with the multimeter, it appears to be working correctly - I have ~2 ohms at low end and 16k at the high (from GND). However, when I go through the calibration sequence with the treadmill powered, the value indicated for that pot counts from 0 up to 255 and resets to 0 about 80% of the way up, then continues to count to ~30.
The panel board seems pretty simple - the brain is a PIC16 uController. I was thinking that many of the resistors on the panel board set dividers that set the voltage input but I don't know if the uController gets involved, or where the PWM is calculated that sets the actual speed (is this way down on the MC-60?).
So, the big question is - is this a problem with the panel board up top or the MC-60 in the base of the unit? The only thing throwing off my suspicion of the MC-60 is that the pot seems to be fine with the multimeter but the displayed value has that weird overflow.
Thanks for any help you can provide.
