problems designing filter
Status
Not open for further replies.
mantaka
Joined Nov 27, 2014
10
i am designing a narrow band pass filter using ua741. when i simulate the circuit on pspice i get exactly what i want.but after implementation i cant vary frequency of the signal by varying resistance.it only varies amplitude of the signal.now what is the problem here i can't figure it out.my circuiis this:
MikeML
5,444
To keep the filter cutoff frequency, you cannot vary just one component.
Put a pot between Vout and gnd as a voltage divider. That way the filter cutoff is not effected by adjusting gain...
mantaka
Joined Nov 27, 2014
10
thank you.what range of pot should i use?amd if i use pot then can i vary frequency of signal?please let me know
MikeML
5,444
Are you trying to make the filter tune-able by varying either the resistances or the capacitors?
Selecting a pot to adjust the amplitude of a signal requires knowing the input impedance of the following stage, and to a lesser extent, the output impedance of the upstream stage...
38,503
You cannot vary the bandpass frequency of such a filter with a single pot. All three resistors need to vary.
Your simulation will show you that.
mantaka
Joined Nov 27, 2014
10
i want 2 vary the frequency of the signal but by varying pot it only varies amplitude.i did simulation and i got exact result i wanted but in practical i can't
mantaka
Joined Nov 27, 2014
10
i did simulation and by varying R2 i can vary the cutoff frequency.i did ac analysis.but after implementation it doesn't work.now what is the problem i can't figure it out.please hep me
mantaka
Joined Nov 27, 2014
10
Post the circuit you simulated with values and power supplies.
upload_2015-3-12_19-47-21.png upload_2015-3-12_19-48-25.png upload_2015-3-12_19-48-36.png
here i applied 4k sinewave signal at input and designed to get this value.during simulation i got the exact value but in lab it doesn't vary frequency.plz help me.now what to do.or wht this doesn't work in lab?
MikeML
5,444
We cannot read the values of the R and Cs.
You seem not to understand this very important point:
The MFB filter you show is not tuneable by changing just one resistor, or just one capacitor. Changing just one resistor, or one capacitor in isolation changes the center frequency, and the shape of the filter. This likely is not useful or desirable...
In order to shift the center frequency of the filter, keeping the bandwidth and other attributes, you must change all three resistors at the same time. (or change the two capacitors at the same time).
mantaka
Joined Nov 27, 2014
10
thank you very much.i did this cause i got this circuit from a link and there was instruction about this circuit to change only R2. that's why i did this.will u can plz help me by showing me a good circuit diagram of narrow band pass filter range of 1kHz.plzzzzz
mantaka
Joined Nov 27, 2014
10
can anyone plz help me by informing me why ua741 doesn't give exact results.i have to give answer to my teacher tomorrow but i don't know the answer.plz plz plz inform me
mantaka
Joined Nov 27, 2014
10
You will have to explain what the shortcoming is...
sorry i didn't understand what u said.i can't find the problems with my circuits.but i have to explain it to my teacher.this is a portion of my thesis.so plz plz plz help me.what should i say about the problems of my circuit.plz .
Status
