Problem_Very simple question, but very strange realty!
Haytham_Salem
Joined Jun 29, 2018
6
Hellow all engineers,
i have a very strange problem for me
it is a simple coil of a dynamometer , it's resistance = 190 Ohm
when i apply a DC voltage = 25 volts
it must drive a current = 131.6 mA
but !!!!!!!!!!!!!!!
in my case the current = 7.5 mA
please someone tell me how come is it??
ebeowulf17
Joined Aug 12, 2014
3,307
Thanks for your quick response ,
i have tried to use so many power supplies
1- the ps of the machine (it is working good).
2- PC psu.
3- other types.
Have you measured the resistance yourself, or is that just a claimed spec?
Also, have you measured 25V across the coil while you were testing it, or is 25V the supply voltage before you connect the coil?
Haytham_Salem
Joined Jun 29, 2018
6
yes, i have measured the resistance myself
i have measured 25V across the PS before the test ,
i tried to measure across the coil during the test by simple PS = not 25 i thought that is because voltage drop on the AVO (!!!)
but i remembered
when i have measured the voltage across the machine PS terminals there was no variation in the volt (when i tried to rise the volt from 0 to 25 or more just the machine max. voltage appears) in the case of this coil
but !!!!
in another dynamo-meter coil (working good) there was a voltage variation
this is my machine
https://www.magtrol.com/wp-content/uploads/dsp6001manual.pdf
in this case my coil PS called "Hysteresis Brake"
Danko
Joined Nov 22, 2017
2,241
but !!!!!!!!!!!!!!!
Resolder magnet wires joints with outer leads and coil will work as new one.
