Problem with setting the set and reset
Fdika24
Joined Dec 23, 2019
I've been trying set my set with the value of 1 and reset with the value of 1 also, but the reset have a button. It seems that in proteus the button does not work properly and my set is equal to 0 rather than 1, is there any explanation on why this is occuring in my proteus projects?
I'm using a 9V Power source
ericgibbs
Joined Jan 29, 2010
21,550
hi,
This is what LTSpice shows with your Set circuit.
E
Update:
There seems to be a problem with MySw. operation?? I will check it out. let you know.
atferrari
Joined Jan 6, 2004
5,022
EDIT/
To the OP: do not read this post. I believe we had a CD4013. WRONG.
Forget this and sorry!
/EDIT
Questions:
Where is pin 6?
If pin 4 is RESET, are you sure pin 7 is SET? Look here:
What is that series of a resistor and a cap before (in series with) the button?
