problem with reciving answer from sim800
STP.Asghari
Joined Nov 22, 2022
12
When I give the AT command to the module. The module should give me the answer AT\r\nOK\r\n but to my surprise it gives the answer AT\r\r\nOOK\r\n. I understood this problem by getting the answer from the code below. While if I delete the wrong lines from the code below, the module does not respond.
sim800 code:
Send_AT();
    do
      buffer=get_char();
    }while(buffer!='A');
        buffer=get_char();
        if(buffer=='T')
                       buffer=get_char();
               if(buffer=='\r')
                             buffer=get_char();
                             if(buffer=='\r')
                                      buffer=get_char();
                                      if(buffer=='\n')
                                                  buffer=get_char();
                                                   if(buffer=='O')
        if(buffer=='O')
        buffer=get_char();
        if(buffer=='K')
        buffer=get_char();
        if(buffer=='\r')
        buffer=get_char();
        if(buffer=='\n')
        for(i=0;i<5;i++)
        HAL_GPIO_WritePin(GPIOC,GPIO_PIN_13,GPIO_PIN_SET);
        HAL_Delay(500);
        HAL_GPIO_WritePin(GPIOC,GPIO_PIN_13,GPIO_PIN_RESET);
        HAL_Delay(500);
