Problem with Electrical Circuit Question
thecarefulone
Joined Mar 14, 2021
Hi! I have a question related to electronics:
Someone told you that there might be a problem with the electrical circuit: In addition to the standard 50Hz alternative voltage, it mights exist another disruptive frequency at 50.5Hz.
For how long, at least, should you measure the voltage in the outlet to know if this disruptive frequency actually exists or if it is a fake information ?
The answer is 2 seconds, but I can't understand why. Can someone explain? Thanks in advance.
ericgibbs
Joined Jan 29, 2010
21,572
hi one,
Welcome to AAC.
Consider if you had a frequency counter that had a display resolution of 1 cycle, how long would you have to wait for a full cycle.?
E
ericgibbs
Joined Jan 29, 2010
21,572
hi,
OK,
Consider you had a frequency counter display that shows '000' Hz [ no decimal parts] how would you display 50.5Hz.?
As it is Homework I can only give you hints.;)
E
Are the 2 frequencies at the outlet co-existing at the same time?
What instrument(s) is being used to measure the signals?
