Ah ok... Sure... Yes I can understand! (After looking 3 times at the circuit I find my self really stupid!
OK. Psy
So with the understanding what effect V1 and D3 will have when a Vin of -15V is input to the circuit, you should now be able to state what Vout is and also the operation of the diodes.
E
BTW: did the Prof specify the -15V input.?
As with your previous circuits, there is a level of -Vin at which the Zener will not be conducting in the zener mode,So, for the original circuit, I think I can say that we will have (Vin - Vzener) at zener's anode and (Vin - Vzener) - Vd1 + V1 at Vout node. Am I correct?
Was this your circuit from post #10?You have virtually done the -Vin part of the problem.
From -Vi = 0V to -(Vz+Vd) the zener/diode path is not conducting, so -Vo = -Vi
Is it this part thats causing you a problem.?From -Vi = 0V to -(Vz+Vd) the zener/diode path is not conducting, so -Vo = -Vi
I do not follow why you are saying you are confused?
Post #10 shows the current path and voltages when the Vi = -15V, so the diode and zener are both conducting, the Vout is close to -10V.
You said you understood that diagram.?
The Ground reference on the circuit is at 0V, the zener's Cathode is at 0V and its Anode is -5V.
ALL the voltages on that circuit are referenced to 0V.
EDIT:
If yes, consider what happens when Vi is less than -(5V+Vd), will the zener/diode be conducting.?
Lets set Vin to -4v in order to test your equation.I wrote it as Vout = (Vin - Vd1 - Vz)/2. It's the same
So, the total voltage drop at this branch will be a key voltage, right? At this voltage, -5.7V, the circuit will change somehow by means of diodes changing their states, right?Lets set Vin to -4v in order to test your equation.
Vout= (-4 - 0.7 - 5) / 2 = -4.85v ; [actual is -4v].
You have to consider the two conditions for -Vin, first when -Vin is > -(Vz+Vd) and second when -Vin < -(Vz+Vd)
Yes, this is the point I have been trying to get you to understand in the last 10 posts.So, the total voltage drop at this branch will be a key voltage, right? At this voltage, -5.7V, the circuit will change somehow by means of diodes changing their states, right?
The change of states is either the diodes/zener are conducting or not.will change somehow by means of diodes changing their states,
So write the transfer function that covers that.
Then do the same for when Vin is 0V to say +15V
You are making this hard work Psy.!
edit corrected '=' to '+'
-Vi >= -(Vz+Vd) <=> Vin <= Vz + VdWhen -Vi >= -(Vz+Vd) then the zener/diode path conducts, so -Vo = -(Vi - (Vz+Vd))/2
How can that be correct.?So Vout = (Vin - Vd1 - Vzener)/2 for Vin < -5.7V
What do you think.?Are you considering -5.7V a lower value than -15V???
Ok, I get your point. I was thinking mathematically!What do you think.?
Consider that you had a car with a 12V battery and the positive terminal was connected to the car chassis.
If you measured the battery with a DMM from chassis to the negative battery terminal when the battery was full charged and it read say -12v
and if the battery battery was partially discharged and you measured say -11v, which is the lower voltage.???
You seem to be having a problem understanding polarities and referencing to a common point of measurement.
Problem with diodes and voltage | Homework Help | 6 | |
| D | diodes & temperature, problem solving the enclosed diode exercise | Homework Help | 3 | |
| S | Multiple Diodes Problem | Homework Help | 19 | |
| K | Problem about Zener Diodes | Homework Help | 15 | |
| T | Problem with diodes | General Science, Physics & Math | 9 |
