Hello all,
It sounds like some body can do favor for me , posting investigation and clarification the solution of the problem indicated below:
(the valve which control the cooling process stays open when it should be off this cause that system continuing cooling far the setting point)
i check if the cause is mechanical problem or electrical issue but i still confused and not reaching to the solution.
thanks in advance
looking to hearing good news
thanks in advance
