Problem with a TOSHIBA RDXV60KB VCR/DVD Recorder
spike1947
Joined Feb 4, 2016
537
Hi
I have a TOSHIBA RDXV60KB VCR/DVD Recorder, not been used very much, but when you switch it on all that happens is like a solenoid switching on and of noise , lights do come on at the front of the machine , have located the part that is making the switching sound ( arrowed on the picture) will try to upload a Service Manual for it, have it in a .pdf format ! .
Any help in what would cause that would be appreciated .
cheers
Spike
SamR
Joined Mar 19, 2019
5,549
The manual is very comprehensive. I did find it amusing that the board is marked HOT and COLD for HI/AC and LO/DC voltage. Just what is the problem? Couple of ways to approach it and first check the power supply rectifier/output. Then go for what is wrong and trace back. Drawing do show test points and I assume test voltages (didn't get that deep into it).
spike1947
Joined Feb 4, 2016
537
Hi
Thanks for your reply , have a bit more info , it could be a Diode, D1150, but I can't find it on the drawing ! .
cheers
spike
SamR
Joined Mar 19, 2019
5,549
There are photo diagrams of the board so it should match up pretty easily. Either that or the parts list should help. Why do you think the diode is bad? Simple enough usually to desolder and test one.
debe
Joined Sep 21, 2010
1,419
Looking at the circuit that relay is Error Voltage detect. So on power up there must be some problem in the powersupply. Check diodes for shorts bulging capacitors in the power board would be a start.
spike1947
Joined Feb 4, 2016
537
Thanks Guys
Was told it is a regular problem with this model, D1150 is the problem Diode ( 1N5397B) but I just can not find it on the drawing ☹! .
Cheers and tks for your replies .
Spike
MH Coghlan
Joined Aug 17, 2023
7
Hi
cheers
Spike
Hi Spike. Did you manage to find & fit the solenoid switch that you identified. If so where did you get the replacement? & if fitted, did your recorder work?
Dodgydave
Joined Jun 22, 2012
11,395
Thank you for your reply. I have an account with Farnell s.
reading the comments made by SPIKE1947, did you think this sounded like the likely component to be causing the ‘switch/alternating fault? Mike C
You need to measure the DC voltages from the transformer outputs ( rectified), ideally the one that feeds the 3V regulator via the diode in question, before you start buying anything.
CPC or Farnells do these relays,
https://cpc.farnell.com/search/prl/results?st=5V relay&gs=true&sort=P_PRICE
spike1947
Joined Feb 4, 2016
537
Hi
Sorry for late reply, only just seen it, TBH I don't remember what I done, it did work in the end, will have to look back n my PC to see if there is some info on it and come back to you.
cheers
Spike
Hi
cheers
Spike
Thanks Spike, awaited your comments, if you find anything, as per your comment.
MC
Hi again
The problem was with the "tape reel movement sensor" took the top off and cleaned it with Meths !, and it worked fine as per pics attached.
Thanks for that - I currently have 5 of these machines - 4 have the fault where you put a VHS tape in, and it all shuts down, I reckon your images have given me the fix I needed.
A couple of them also have the relay that plays up too.
To all the people that have posted on this thread, it's much appreciated ..... the faulty tape sensor is along the same lines as a audio cassette deck I fixed last year, that's all working now
