Problem of having both short circuit and voltages in output of power supply
Saeedk9574
Joined Jan 1, 2024
35
Hello everyone,
My computer power supply is short circuit in the output when I test it by multimeter, although it has all the voltages including 12, 5 and 3.3. So what is the reason of that while it provides these voltages and works without problem, but it is short circuit. Is it dangerous to use it in this way?
Saeedk9574
Joined Jan 1, 2024
35
HI Saeed, what makes you think your PC power supply is shorted? How are you testing it? Does the PC turn on as normal?
More details more details...
Actually, I do not use it for pc. I use it as a power supply for my projects and circuits as it has useful voltages (12, 5 and 3.3).
Simply with continuity mode of multimeter I checked + and - of power output, then surprisingly I heard the beep sound. However, As I mentioned it has that voltages in the output.
WBahn
Joined Mar 31, 2012
32,777
I'm assuming you are measuring the continuity when the supply is powered down? Sure hope so.
Why are you even making this measurement? What is it you are trying to find out?
It's shouldn't come as a surprise that a power supply behaves differently when it is powered up and when it isn't. There can be a number of reasons why it looks like a low resistance at the output when it is powered down. As Ian0 said, one reason is that your meter is having to charge an output capacitor, which might take some time (might even take forever is the leakage current of the capacitor exceeds the continuity test current of your meter).
Saeedk9574
Joined Jan 1, 2024
35
Yes, I have tested continuity when the power supply is off. As I did not hear the beep sound in the another power supply I have, I supposed this one may have problem.
Thank you, I appreciate you. It was really helpful.
seanstevens
Joined Sep 22, 2009
323
So when you power up the PC PSU, do you get the right voltages on the outputs as you stated in your first post? I also presumed you must have the enable link in place to get it to output anything without it being in the PC.
If you are getting the right voltages and currents on all the outputs, then I presume it works. Maybe the beep on your meter is caused by something else and is unrelated?
Besides the beep, do you have any other history on the PSU, why is it not in a PC, was it faulty...
