"Unauthorized Personnel Only"?Needs a caption:
This is what you get for not playing ball.https://www.404media.co/eric-adams-told-fbi-he-forgot-his-phones-passcode/
Eric Adams Told FBI He Forgot His Phone’s Passcode
“But, Adams further claimed, he had forgotten the password he had just set, and thus was unable to provide the FBI with a password that would unlock the phone.”
Try: IAmNotACrook2024
+1This is what you get for not playing ball.
cyberattack tied to the Chinese government penetrated the networks of a swath of U.S. broadband providers, potentially accessing information from systems the federal government uses for court-authorized network wiretapping requests.
For months or longer, the hackers might have held access to network infrastructure used to cooperate with lawful U.S. requests for communications data, according to people familiar with the matter, which amounts to a major national security risk. The attackers also had access to other tranches of more generic internet traffic, they said.
Verizon Communications, AT&T and Lumen Technologies are among the companies whose networks were breached by the recently discovered intrusion, the people said.
The widespread compromise is considered a potentially catastrophic security breach and was carried out by a sophisticated Chinese hacking group dubbed Salt Typhoon. It appeared to be geared toward intelligence collection, the people said.
https://9to5mac.com/2015/11/17/opinion-apple-encryption/The surveillance systems believed to be at issue are used to cooperate with requests for domestic information related to criminal and national security investigations. Under federal law, telecommunications and broadband companies must allow authorities to intercept electronic information pursuant to a court order. It couldn’t be determined if systems that support foreign intelligence surveillance were also vulnerable in the breach.
Second, Apple is absolutely right to say that the moment you build in a backdoor for use by governments, it will only be a matter of time before hackers figure it out.
You cannot have an encryption system which is only a little bit insecure any more than you can be a little bit pregnant. Encryption systems are either secure or they’re not – and if they’re not then it’s a question of when, rather than if, others are able to exploit the vulnerability.
Couple a deliberately weakened form of encryption to laws requiring Internet service providers and telecoms companies to stockpile large volumes of user data and you’d create the biggest goldmine the world has ever seen for criminals to commit identity theft and other forms of fraud. Not just private enterprise criminals, either, but rogue nations too.
Better: one should strive to minimize the attack surface -- the opposite of allowing back doors.I wish they hadn't built their argument on the notion that encryption systems are either secure or they're not. By that reasoning, since no encryption system is secure, then every encryption system is insecure, so there's no fundamental reason to not require government back doors.
Security always involves compromises. The opinion should be based on what constitutes reasonable and acceptable compromises. The argument they made in the last quoted sentence is perfectly applicable to justifying the position that intentional backdoors are not acceptable compromises.
There are encryption systems that are secure (given some conditions) but not convenient to the casual user. It's what used for EAM and Nuclear authentication methods.I wish they hadn't built their argument on the notion that encryption systems are either secure or they're not. By that reasoning, since no encryption system is secure, then every encryption system is insecure, so there's no fundamental reason to not require government back doors.
Perfect secrecy
One-time pads are "information-theoretically secure" in that the encrypted message (i.e., the ciphertext) provides no information about the original message to a cryptanalyst (except the maximum possible length[note 1] of the message). This is a very strong notion of security first developed during WWII by Claude Shannon and proved, mathematically, to be true for the one-time pad by Shannon at about the same time. His result was published in the Bell System Technical Journal in 1949.[19] If properly used, one-time pads are secure in this sense even against adversaries with infinite computational power.
Shannon proved, using information theoretic considerations, that the one-time pad has a property he termed perfect secrecy; that is, the ciphertext C gives absolutely no additional information about the plaintext.[note 2] This is because (intuitively), given a truly uniformly random key that is used only once, a ciphertext can be translated into any plaintext of the same length, and all are equally likely. Thus, the a priori probability of a plaintext message M is the same as the a posteriori probability of a plaintext message M given the corresponding ciphertext.
Same issue -- you can always reduce the attack surface further, but at the expense of other security goals, particularly availability. So just because not allowing a back door reduces the attack surface is not, by itself, a sufficient justification for not allowing (or requiring) them. It has to be based on a reasoned, valid, and coherent argument that allowing/requiring them increases the attack surface so much that the net effect on the overall security framework is to weaken it in an unacceptable way -- i.e., that the benefits (and there ARE legitimate benefits) do not come close to outweighing the costs. That's a pretty easy argument to make -- that one sentence that was quoted is a very good start at doing so.Better: one should strive to minimize the attack surface -- the opposite of allowing back doors.
And yet, even one time pads have proven to be insecure.There are encryption systems that are secure (given some conditions) but not convenient to the casual user. It's what used for EAM and Nuclear authentication methods.
https://en.wikipedia.org/wiki/One-time_pad
"a cable specifically designed for penetration testing by a security researcher. So, yes, it's a feature"
The O.MG Cable is a hand made USB cable with an advanced implant hidden inside. It is designed to allow your Red Team to emulate attack scenarios of sophisticated adversaries. Until now, a cable like this would cost $20,000 (ex: NSA's COTTONMOUTH-I). These cables will allow you to test new detection opportunities for your defense teams. They are also extremely impactful tools for teaching and training.
The uncompromising attention to the physical size of the cable isn't where we stopped. Thanks to continual firmware updates, the resulting power, flexibility, and ease of use have made the O.MG Cable a favorite for both new students and seasoned pros.
I can't tell: are you playing down the threat, or making fun of those who do?"a cable specifically designed for penetration testing by a security researcher. So, yes, it's a feature"
https://shop.hak5.org/products/omg-cable
| Thread starter | Similar threads | Forum | Replies | Date |
I lost the ability to go to local IP addresses. | General Electronics Chat | 20 | |
Privacy and security tips for windows android and ios | Off-Topic | 0 | |
You're 4 microseconds late, Jetson! NTP at NIST Boulder has lost power | General Science, Physics & Math | 9 |
