Printing the variables address using pointers in c++
asilvester635
Joined Jan 26, 2017
73
Why won't it print the address???
Code:
int a = 10;
    int* p;
    p = &a;
    int size = sizeof(int);
    printf("Address of p is %d\n", p);
    printf("Size of integer is %d\n", size);
    printf("Address p+1 is \n", p+1);
The error it's giving me is below
g++ -c -Werror main.cc
main.cc:20:33: error: format specifies type 'int' but the argument has type
'int *' [-Werror,-Wformat]
main.cc:22:30: error: data argument not used by format string
[-Werror,-Wformat-extra-args]
2 errors generated.
make: *** [main.o] Error 1
Papabravo
Joined Feb 24, 2006
22,116
Because the types are not interchangeable. The format specifier in the the printf function call (%d), requires an integer. The type of the argument is pointer to integer. You used to be able to get away with this false equivalence, but I'm guessing that the compiler is calling you out for your ham-handed attempt to bypass strong type checking. Do you know what a typecast is?
In the second case the format specifier string has do description of the type for p+1. It just contains characters that are printed literally.
You might want to go back an restudy the first principles of such things because it seems they went right over your head on first reading. Also it might be worthwhile for you to study the library code for printf. It was one of the first things I did when I learned the C-language in 1978. Although the compiler might be C++, you are using any C++ syntax or semantics yet.
WBahn
Joined Mar 31, 2012
33,098
Also, on many modern compilers, a pointer is an 8-byte unsigned integer, not a 4-byte unsigned integer. So I would recommend casting your pointer to an 8-byte unsigned integer (which may be a long or may be a long long) and then using the corresponding format specifier.
