Printing IC pinouts using a normal printer
Mozee
Joined Jul 23, 2016
87
Hello folks,
I was wondering If there is a way to print IC pinouts on normal A4 papers then cut them manually into the IC size. Is there any software having a library of printable IC pinouts? Any simple and practical way to do so? Ideas?
bertus
Joined Apr 5, 2008
22,995
Do you mean something like these?
You can find those in the datasheets/databooks.
The shown image come from the TI databook wic can be found as scyd013.pdf on the internet.
I do not know any software capable of this.
Bertus
35,093
Hello folks,
Google IC pinout labels.
Alec_t
Joined Sep 17, 2013
15,152
Will the printout be used just for labelling an IC, or does it have to be the exact size of the IC (e.g. for marking out a pcb for drilling) ?
Mozee
Joined Jul 23, 2016
87
Thanks guys. Actually I would like to print the pinouts e.g. IC555 timer pinouts which are VCC TRH TRI GND RST etc etc .. and not the number of op-amps or gates etc.. the label must fit on the IC as I will glue it so when I breadboard I wouldn't have to refer back to the datasheet
dl324
Joined Mar 30, 2015
18,453
Most would put pinout/function information on the schematic:
That's what you're going to use to wire and/or troubleshoot the circuit.
