How's the working mechanism of the sucker or pump suction in Hakko desoldering gun or other product alike?
Suction...How's the working mechanism of the sucker or pump suction in Hakko desoldering gun or other product alike?
It's usually a small vacuum pump. Doesn't take much vacuum to do desoldering.How's the working mechanism of the sucker or pump suction in Hakko desoldering gun or other product alike?
Ok, your interpretation of "mechanism" made more sense than mine. I thought he was asking about "principle of operation."It's usually a small vacuum pump. Doesn't take much vacuum to do desoldering.
I think he is talking about the gun which has a hollow core soldering tip:The mechanism is an O-Ring sealed single stroke vacuum pump that is powered by a spring. There is a mechanical hand operated release on the latch that holds it in the cocked position. TRiggering it causes the spring to rapidly withdraw the piston, creating the vacuum. The exact nature of the latch varies with model.
I don't think that most Hakko desoldering guns use a manually operated spring vacuum pump, but rather an electrical vacuum pump in the hand piece or in the base station.The mechanism is an O-Ring sealed single stroke vacuum pump that is powered by a spring. There is a mechanical hand operated release on the latch that holds it in the cocked position. TRiggering it causes the spring to rapidly withdraw the piston, creating the vacuum. The exact nature of the latch varies with model.
Glad to see I'm not the only one who saw "mechanism" and thought "principle of operation" rather than "physical apparatus."...it's principle was...
Whether is it overpriced depends on your requirements. We use the Hakkos in an undergrad electronics lab and they worked for years, easily, with only a little instruction.They also strike me as being very overpriced. I notice that they sell the classic hand desoldering pump for $18.97 when you can buy a set of five of them on Amazon for $9.
Yes, the tips can last a long time—but they can also be destroyed by an unskilled operator. It also requires some skill to get the tip in a position where it will effectively suck up the molten solder. This is part of the reason for the destroyed tips, the unskilled operator thinks shoving the tip up to the iron is the answer.I've always used either solder wick or the old-fashioned hand-operated spring & piston pump. The one I have I bought at Radio Shack about thirty years ago and I still have the original tip. I don't know what it's made of, seems like nylon, but I'm not at all certain. It shows almost no signs of melting.
