Prevent current stopping when connection is broken.
Monkeybus
Joined Dec 29, 2017
6
Hello everyone, my first question here. Hope it's not too ignorant.
You know how audio stops playing when you unplug headphones?
I have a digital TENS machine that stops if the connection to an electrode is broken.
I want to use a Raspberry Pi to automatically switch a TENS channel between more than one electrode. I'll try using a relay or a transistor for that.
But how do I prevent the TENS unit from killing the current when I change to a different electrode? I want to seamlessly move the current from one electrode to another. The TENS unit only has two channels.
Does that question make sense?
Thanks a lot folks.
38,952
You can leave one connected until the next is connected (both are momentarily connected for a short time).
That should keep the TENS machine from disconnecting.
Monkeybus
Joined Dec 29, 2017
6
That makes a lot of sense. Thanks a lot.
While I'm asking questions, the TENS unit is rated at 180V, 70mA
Does anyone know the best way to switch that kind of signal?
I know zero about electronics, bar some basic theory.
Thanks a lot.
