Pretty good weekend effort
cmartinez
Joined Jan 17, 2007
8,897
Oh! And, @cmartinez, no ground plane.
Man ... that is great news. I already bought the "Noise Reduction Techniques" book that you recommended, but I haven't started reading it... now I will.
And btw, Joey ... you're not the only one who's been avidly working on something new. I too have been developing a top secret project for the last 4 months, and the crucial viability tests will be this weekend... wish me luck!
joeyd999
Joined Jun 6, 2011
6,562
you're not the only one who's been avidly working on something new. I too have been developing a top secret project for the last 4 months...
Post some details...obscure enough that your "competitors" will not figure out what you're doing.
Good luck.
joeyd999
Joined Jun 6, 2011
6,562
For those wanting a bit more detail:
The sensor measures a real-world signal. The physical signal has a strong 1/f component that would stretch out over decades or centuries. That is the reason for the noise increase as frequency approaches DC.
joeyd999
Joined Jun 6, 2011
6,562
My proof-of-concept for the new sensor is complete and fully tested. Here are some final stats:
Power supply: 2 'AA' batteries (about 100 hours of life) or 3-24VDC external power.
Four switching regulators.
Two voltage references.
Three SPI devices: 2 channels of 24 bit A/D @ 7.5 SPS, 2 channels of 24 bit A/D at 60 SPS, 1 channel of 16 bit D/A at 30 SPS.
Two EUSART devices: 1 RS-232 @ 19.2KBaud, 1 Bluetooth Radio at 115KBaud.
One parallel device: 2x16 character LCD display with backlight.
2 channels of on-chip 12 bit A/D at 1,953 SPS.
On-chip EEROM -- write leveled.
4 push-buttons and mechanical quadrature encoder with integrated 5th push-button.
Two on-chip timers: Timer0 and Timer1, and CCPM1 in compare mode attached to Timer 1.
2 hi-priority interrupt sources, 8 low-priority interrupt sources.
16,664 lines of assembly code for an 18F65K22 MCU.
Clock speed: 8Mhz on-chip oscillator.
21,553 of 32,768 bytes of program memory used.
1,907 of 2,048 file registers used.
I can say now, with 100% certainty, that this project could never have been implemented on this hardware in C.
brightnight1
Joined Jan 13, 2018
97
Seems like a wicked cool project, excited (and a bit jealous) for you and your knowledge. I hope you post what it's about sometime soon. I just read 9 pages of posts and still don't know what you're making :)
joeyd999
Joined Jun 6, 2011
6,562
This is a chart of the noise performance with the addition of a 10s digital rise-time filter (RC) at the end of the signal chain. The scaling of the data changed a bit from post 164, so the DC level is about 120 dB, not 140 dB as above.
But, notice that the noise floor beyond 1 Hz is 170 dB (!) down from the DC level.
joeyd999
Joined Jun 6, 2011
6,562
And, while I didn't show it here, the noise actually improves as the DC level gets smaller. I achieved this by using two 24 bit ADCs. The top-end ADC covers about 50dB of the dynamic range. The low-end ADC covers about 100dB of the dynamic range.
The two outputs are blended at the transition for smooth crossover.
cmartinez
Joined Jan 17, 2007
8,897
Blended as in averaged? ... or did you use some other technique?
Also, what 24-bit ADC chip are you using?
joeyd999
Joined Jun 6, 2011
6,562
One is my go-to standard ADS1242. The other is secret for this discussion.
The transition occurs between two defined levels, with each output contributing a portion of the blended signal within the transition band. The proportion of each is just a linear function of the position between the two transition points.
