I'd say that unless you've conclusively established the cause of this offset (not just suspecting it) and found a cure that's 100% effective in every case, it's impossible to know if the offset is going to change with time or be consistent. If it were me, I wouldn't count on consistency and would redouble my efforts to find the actual cause of the offset-- your sensors simply should not be behaving that way.I feel it is to do with the capacitor destabilising the amplifier inside the transducer as OBW0549 has said. (...) I tested a sample of 10 similar transducers today. Each one has this d.c. offset voltage... But not all the same value - most aren't out by enough to affect the performance of the system, but some clearly are. Does anyone know if the offset is likely to change over time? I can accept some margin of error as long as it will perform consistently. i.e. if there is some offset will it get worse?
Frankly, at this point I'm at a loss as to what the problem could be.
