thingmaker3
- Joined May 16, 2005
- 5,083
Originally posted by NewGuy+May 13 2006, 06:07 PM--><div class='quotetop'>QUOTE(NewGuy @ May 13 2006, 06:07 PM)</div><div class='quotemain'> (O/P, Mofet Switch, Comparator, Voltage Divider) These are electrical components I've never heard of.[post=17063]Quoted post[/post][/b]
"o/p" = "output"
"mosfet" = metal oxide semiconductor field effect transistor = the thing in Ron's schematic labled "M1" - we're using it as a solid state switch in this application.
"comparator" = an op amp (operational amplifier) configured to compare a voltage input with a reference inptu - Ron has chosen half of an LM393 (a common integrated circuit op amp, two to a chip) and labled it "U1a" in his schematic.
R3 and R6 form a "voltage divider" which sets the reference voltage. It divides the applied voltage by the ratio of the two resistances. R5 is your pressure sensor, which forms another voltage divider with R8 and R2, thereby developing a voltage proportional to the pressure applied.
R8 allows for adjustment to compensate for variation between individual sensors - it is a "variable resistor" or "potentiameter." It is the "trim pot" I spoke of. "Trim" means "adjusted by creator or manitainer rather than by operator."
A trim pot is not a typically a user adjustment, but a more user convenient pot could be used instead. This would require the doofarb to be calibrated by the user.Originally posted by NewGuy@May 13 2006, 06:07 PM
This item called a Trim Pot; if one is used, can it be used as a type of manual adjustment by the end user of this little electrical gizmo to adjust the sensitivity of the force sensor to a specific force bewteen 0 to 100 pounds?[post=17063]Quoted post[/post]
With the batteries on a separate board, using SMT (surface mount technology) components and a bit of fussing around - maybee 1" x 1.25" x 1/2". Without the SMT, which would be easier to build, maybee 5% or 10% bigger. (Would need a different MOSFET if you go without SMT. No big problem.)Originally posted by NewGuy@May 13 2006, 06:07 PM
Just for the sake of argument, lets say we used all or most of the electrical components you've just listed. How much space will a circuit consisting of such components take up? Can they be assembled in a "Micro-Circuitry" type of configuration?[post=17063]Quoted post[/post]
Depends on where one shops. With all new components from a reputable supply house, maybee ten or twenty bucks. From Radio Schmuck, maybee twice that. With surplus parts and some digging around online, maybee five or ten bucks. SMT parts are a little harder to find through surplus.Originally posted by NewGuy@May 13 2006, 06:07 PM
What would be a ball park price of the individual components you've listed?[post=17063]Quoted post[/post]
Can I ever!! Scroll up to the top of this page. Look for the smaller "All About Circuits" under the larger identical phrase. Click on it! Enjoy!Originally posted by NewGuy@May 13 2006, 06:07 PM
Can you recommend a website with some kind of Electronics Glossary where I might be able to look up the meanings and applications of some of the components you mentioned? I'd like to be just a little bit smarter the next time I log onto this site if I can.[post=17063]Quoted post[/post]
<!--QuoteBegin-NewGuy@May 13 2006, 06:07 PM
"Dios te lo paga."
[/quote]De nada, hombre, de nada. Besides, Ron H did all the work...
