Preamplifier circuit for towing hydrophone array isn’t working
Cmhhawaii
Joined Aug 2, 2018
1
I am attempting to make a towing hydrophone for listening to whales. I am following the instructions posted by NOAA here: https://swfsc.noaa.gov/uploadedFile... et al 2008 HydrophoneConstruction_TM-417.pdf
I have completed my board, but it doesn’t produce any sound. Looking for some help on diagnosing where I may have gone wrong....
Are my capacitors backwards? Wrong preamp chip? Not really sure.
Any help would be greatly appreciated.
837E1C07-F2D4-45D3-A45E-D2C2155CE42F.jpeg BFB6F868-038B-4E29-9434-1B18E0B42CAF.jpeg image.jpg image.jpg image.jpg
Externet
Joined Nov 29, 2005
2,636
Hi.
If you have another AD743, try instead installing a 8 pin socket and complete soldering your project to the socket, keeping The IC in electrostatic-safe packaging until all done, then insert caring for ESD.
I do not like the circuit does not have counterparalleled diodes to clip the piezoelement spikes voltage.
I would implement such before inserting the new AD743 in its socket.
Is there a DPST switch to power on ?
The 3 'Gnd' board pins; are they hooked somewhere ?
And I do not understand the "Hydrophone elements never provide much output voltage" statement on the schematic.
And piezoelements must be mechanically held at the rim, do not use/test just on air hanging by its wires.
ebp
Joined Feb 8, 2018
2,332
The first thing I would do is measure all of the In-use pins of the op amp relative to circuit common ("ground"). Pins 4 and 7 should have the appropriate supply voltages of course. The output and the two input pins should all be very close to the same DC voltage and within a few millivolts of zero (because of C1, the amplifier has a gain of 1 at DC and the only DC at the input should be due to "input offset voltage" of the amp, which should be in the low millivolts range, at most).
ebp
Joined Feb 8, 2018
2,332
If the voltages look OK and you have another 10 µF or larger capacitor handy, try this:
- bridge the 10 µF across the C1 temporarily; this increases the gain at low frequency
- touch the input that would normally go to the transducer with a finger. This will couple AC mains "noise" into the input, unless your doing this well away from any AC power lines. The gain will be about 30-40 at mains frequency, so you should get a fairly large signal at the output. Be careful if you have the output connected to an audio amp - turn the amp down to avoid a loud rude surprise.
I'm assuming you are confident that your piezo transducer responds in the frequency range of interest.
