Powering a laptop with a bench power supply
metiz
Joined Oct 27, 2014
62
I just bought a 2nd hand laptop with a missing power supply (HP easynote Ls). It's up in the air if this thing actually works so I want to hook up a bench power supply to test it out before I buy an adapter. The laptop requires 3.42A at 19 volts. My power supply (HPS-3025) can deliver no more than 2.5A. I believe the power supply has a constant voltage output and a current limiter.
The power supply should be fine, but what about the laptop? It may start with the low current, it may not, but can I damage it trying this? What if I disconnect the battery and harddrive to keep power consumption as low as possible?
AlbertHall
Joined Jun 4, 2014
12,663
I don't think it will damage the laptop if the voltage is less than it should be - but of course it may not work properly.
If it works on the PSU, all well and good, but if it doesn't then you will be none the wiser. You won't know whether it didn't work because it doesn't work or if it failed because of a voltage drop.
metiz
Joined Oct 27, 2014
62
Do you mean current?
Dodgydave
Joined Jun 22, 2012
11,395
Just set the voltage to 19v and maximum current limit,with correct polarity the laptop will draw its own current as needed.
35,299
Follow instructions in post #4.
Leave the laptop closed and charge the battery for up to 8 hours (assuming the battery is not on its way out).
ian field
Joined Oct 27, 2012
6,536
You might get away with charging the battery as long as you don't try to operate it before its fully charged.
mcgyvr
Joined Oct 15, 2009
5,394
The 3.42A is likely the current draw when its charging the battery, CPU pegged to 100%, fans going full speed,etc..
It will probably draw much less during normal (not maxed to capacity) operation..
Just don't try to run extreme benchmarking tests,etc.. and it should be just fine assuming you set the benchtop supply to 19V..
I doubt a computer would be hurt if the voltage were to sag..
