Quite possibly. It would be interesting to see data proving the 40% claim. Or is it anecdotal?They say its a capacitor bank... Is it a power factor corrector??
So far so good, its called noise.Electrical flow is not stable. It contains small power spikes which can not be used by your appliances.
How? By what mechanism does noise on the power line 'leak' usable electricity from your circuit? Where does this so-called usable elecricity get leaked to?These spikes 'leak' usable electricity from your circuit and get converted to heat inside our electrical wires which can damage your appliances over time.
Quite possibly it does but since domestic users are not charged for power factor does it really matter?Our PowerSaver 9 uses a system of capacitors and patented components to smooth out these power spikes which increases the power factor in your circuits
Just where do these miraculous savings come from? Its can't be the power factor correction and if noise on your power line is making your power meter spin 15% to 40% faster then you really should be talking to your power supply company. Not to mention that so much noise on the mains would make it impossible to watch TV or listen to the radio, stereo etc.Ultimately, this means that you are using the electricity you already have more efficiently than before and results vary between 15% and 40% depending on your location and the quality of the electricity supply in your area.
Ya... plug it anywhere in your house. So that your neighbourhood will also benefit from the device connected in parallel on the common circuit.. This is impossible unless the current flows 'through' it and not just 'by' it... It is sure a capacitor bank then..We suggest plugging your PowerSaver into an unused power socket in a convenient location where you have no need to disturb it. Turn the power on, forget about it
My 100Ah Inverter battery wont take that long to charge from empty to full.. i dont believe it unless I get to know it internally..It is recommended to keep your PowerSaver plugged in permanently. Our PowerSavers work by storing electricity internally and then releasing it. It can take 2-3 days for your PowerSaver to store this electricity most efficiently and, if you unplug or power off your PowerSaver it will take a further 2-3 days to return to it's optimal state
I've got five bucks says there's no scientific testing. A Thai power bill in an information vacuum is worth less than the greasy napkin I just threw away. Any hard tests with the thing being turned off after all the other energy saving measures have been taken? Any? Hmmm? None?To alleviate the concerns of the more technical members here at AAC, care to share with us how your come to the conclusion that you get a 40% saving on electricity bills when using your device?
| U | Led on dimmer power usage | General Electronics Chat | 5 | |
| M | R/S flip flop usage in DC/DC converters | Power Electronics | 5 | |
Transformer power in reversed usage? | Power Electronics | 21 | |
Power adapter specs and usage | Power Electronics | 3 | |
Finding power usage of fridge | Power Electronics | 33 |
