Power adapter specs and usage
Gpag
Joined Oct 29, 2023
I have a generator that has a rechargeable battery. The output specs on the AC adapter to charge the battery are 12V DC 1000mA. I cannot find the AC adapter. I do have an adapter that has output specs of 12V DC 0.75A.
Could I use this adapter to charge the battery or will the reduced output of 0.25A damage the battery and charging system?
dl324
Joined Mar 30, 2015
18,476
If the battery is SLA, a regular 12V adapter won't work. Even if the voltage was high enough to charge the battery (around 13.8V), it won't charge the battery correctly. A battery maintainer would be more appropriate. Most will also try to recondition dead batteries.
I've recovered several 12V SLA batteries using maintainers, and several car batteries. None would hold a charge. They do now, but they're still weak. It took months to get some of them to charge.
